Watchdog reset, effect on I/O pin & ZERO_FILL
cparsons
PostPosted: Fri Jun 13, 2008 9:19 am     Reply with quote
compiler version: PCWH V4.070
I'm using one of the port D PIC18F4580 pins to control the active-low reset line of another peripheral.
In the case that the PIC resets due to a watchdog timeout I don't want the other peripheral also being reset - I'd like the pin to stay high.
The details of the PIC register values after a soft reset seem to indicate the Port D pins will be unchanged.
If I look at the pin with scope during a watchdog reset I see the pin voltage dip down to 1.9V over a period of 200us before going back up to the 3.3V, the high voltage.
If I create a much smaller program that configures a few registers then causes a watchdog reset then the voltage dip is of the order of a few microvolts over 15us.
If I compare the two .lst files I see that the larger program has about 500 CLRF instructions before the main() function instructions, presumably clearing memory and registers. The smaller program uses much less RAM so only has a couple of CLRF instructions before main().
I've read the documentation, and see the #ZERO_FILL compiler directive. I can't find anywhere in my code where I have included this directive, nor can I find an option for it in the IDE.
- Can anyone see why the CLRF instructions would have a bearing on the pin during a reset?
- If not, are there any other factors that influence the voltage on the pin through a reset?
- Is ZERO_FILL enabled by default on some versions of the compiler? If so, is there a way to turn it off?
Thank you
Chris Parsons
Here is the first instructions of the short program with the very ouput pin voltage dip:
CCS PCH C Compiler, Version 4.070, 41847               13-Jun-08 14:31
               Filename: ResetPinTest.lst
               ROM used: 490 bytes (1%)
                         Largest free fragment is 32278
               RAM used: 10 (1%) at main() level
                         13 (1%) worst case
               Stack:    1 locations
0000:  GOTO   00D4
<---snip--->
.................... #use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)
.................... #FUSES WDT512                   //Watch Dog Timer uses 1:256 Postscale
.................... #FUSES EC_IO                    //External clock
.................... #FUSES NOPROTECT                //Code not protected from reading
.................... #FUSES BROWNOUT                 //Reset when brownout detected
.................... #FUSES BORV28                   //Brownout reset at 2.8V
.................... #FUSES NOPUT                    //No Power Up Timer
.................... #FUSES NOCPD                    //No EE protection
.................... #FUSES STVREN                   //Stack full/underflow will cause reset
.................... #FUSES NODEBUG                    //Debug mode for use with ICD
.................... #FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
.................... #FUSES NOWRT                    //Program memory not write protected
.................... #FUSES NOWRTD                   //Data EEPROM not write protected
.................... #FUSES NOIESO                   //Internal External Switch Over mode disabled
.................... #FUSES NOFCMEN                  //Fail-safe clock monitor disabled
.................... #FUSES PBADEN                   //PORTB pins are configured as analog input channels on RESET
.................... #FUSES BBSIZ2K                  //2K words Boot Block size
.................... #FUSES NOWRTC                   //configuration not registers write protected
.................... #FUSES NOWRTB                   //Boot block not write protected
.................... #FUSES NOEBTR                   //Memory not protected from table reads
.................... #FUSES NOEBTRB                  //Boot block not protected from table reads
.................... #FUSES NOCPB                    //No Boot Block code protection
.................... #FUSES LPT1OSC                  //Timer1 configured for low-power operation
.................... #FUSES MCLR                     //Master Clear pin enabled
.................... #FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
.................... #bit RCON_POR = 0x0FD0.1
.................... #define PIN_PPC750FL_HARD_RESET     (PIN_D7)
00D4:  CLRF   FF8
00D6:  BCF    FD0.7
00D8:  CLRF   FEA
00DA:  CLRF   FE9
00DC:  BCF    FB8.3
00DE:  MOVLW  17
00E0:  MOVWF  FAF
00E2:  MOVLW  A2
00E4:  MOVWF  FAC
00E6:  MOVLW  90
00E8:  MOVWF  FAB
00EA:  MOVF   FC1,W
00EC:  ANDLW  C0
00EE:  IORLW  0F
00F0:  MOVWF  FC1
00F2:  MOVLW  07
00F4:  MOVWF  FB4
00F6:  CLRF   05
....................    long int count;
....................    setup_wdt(WDT_ON);
00F8:  BSF    FD1.0
....................    if (RCON_POR == 0)
00FA:  BTFSC  FD0.1
00FC:  BRA    0102
....................       hardReset = 1;
00FE:  MOVLW  01
and this is the equivalent code for the normal program
CCS PCH C Compiler, Version 4.070, 41847               13-Jun-08 14:36
               Filename: PMN_main.lst
               ROM used: 18144 bytes (55%)
                         Largest free fragment is 14620
               RAM used: 589 (38%) at main() level
                         663 (43%) worst case
               Stack:    7 worst case (5 in main + 2 for interrupts)
0000:  GOTO   40DA
<---snip - fuse configuration should be the same as above --->
.................... void main ()
40DA:  CLRF   FF8
40DC:  BCF    FD0.7
40DE:  BSF    0D.7
40E0:  CLRF   FEA
40E2:  CLRF   FE9
40E4:  BCF    FB8.3
40E6:  MOVLW  17
40E8:  MOVWF  FAF
40EA:  MOVLW  A2
40EC:  MOVWF  FAC
40EE:  MOVLW  90
40F0:  MOVWF  FAB
40F2:  MOVF   FC1,W
40F4:  ANDLW  C0
40F6:  IORLW  0F
40F8:  MOVWF  FC1
40FA:  MOVLW  07
40FC:  MOVWF  FB4
40FE:  MOVLW  40
4100:  MOVWF  2B
4102:  MOVLW  42
4104:  MOVWF  2C
4106:  MOVLW  0F
4108:  MOVWF  2D
410A:  CLRF   2E
410C:  CLRF   33
410E:  CLRF   34
4110:  CLRF   35
4112:  CLRF   36
4114:  CLRF   37
4116:  CLRF   38
4118:  CLRF   39
411A:  CLRF   3A
411C:  CLRF   3B
411E:  CLRF   3C
4120:  CLRF   3D
4122:  CLRF   3E
4124:  CLRF   3F
4126:  CLRF   40
4128:  CLRF   41
412A:  CLRF   42
412C:  CLRF   43
412E:  CLRF   44
4130:  CLRF   45
4132:  CLRF   46
4134:  CLRF   47
4136:  CLRF   48
4138:  CLRF   49
413A:  CLRF   4A
413C:  CLRF   4B
413E:  CLRF   4C
4140:  CLRF   4D
4142:  CLRF   4E
4144:  CLRF   4F
4146:  CLRF   50
4148:  CLRF   51
414A:  CLRF   52
414C:  CLRF   53
414E:  CLRF   54
4150:  CLRF   55
4152:  CLRF   56
4154:  CLRF   57
4156:  CLRF   58
4158:  CLRF   59
415A:  CLRF   5A
415C:  CLRF   5B
415E:  CLRF   5C
4160:  CLRF   5D
4162:  CLRF   5E
4164:  CLRF   5F
4166:  CLRF   x60
4168:  CLRF   x61
416A:  CLRF   x62
416C:  CLRF   x63
416E:  CLRF   x64
4170:  CLRF   x65
4172:  CLRF   x66
4174:  CLRF   x67
4176:  CLRF   x68
4178:  CLRF   x69
417A:  CLRF   x6A
417C:  CLRF   x6B
417E:  CLRF   x6C
4180:  CLRF   x6D
4182:  CLRF   x6E
4184:  CLRF   x6F
4186:  CLRF   x70
4188:  CLRF   x71
418A:  CLRF   x72
418C:  CLRF   x73
418E:  CLRF   x74
4190:  CLRF   x75
4192:  CLRF   x76
4194:  CLRF   x77
4196:  CLRF   x78
4198:  CLRF   x79
419A:  CLRF   x7A
419C:  CLRF   x7B
419E:  CLRF   x7C
41A0:  CLRF   x7D
41A2:  CLRF   x7E
41A4:  CLRF   x7F
41A6:  CLRF   x80
41A8:  CLRF   x81
41AA:  CLRF   x82
41AC:  CLRF   x83
41AE:  CLRF   x84
41B0:  CLRF   x85
41B2:  CLRF   x86
41B4:  CLRF   x87
41B6:  CLRF   x88
41B8:  CLRF   x89
41BA:  CLRF   x8A
41BC:  CLRF   x8B
41BE:  CLRF   x8C
41C0:  CLRF   x8D
41C2:  CLRF   x8E
41C4:  CLRF   x8F
41C6:  CLRF   x90
41C8:  CLRF   x91
41CA:  CLRF   x92
41CC:  CLRF   x93
41CE:  CLRF   x94
41D0:  CLRF   x95
41D2:  CLRF   x96
41D4:  CLRF   x97
41D6:  CLRF   x98
41D8:  CLRF   x99
41DA:  CLRF   x9A
41DC:  CLRF   x9B
41DE:  CLRF   x9C
41E0:  CLRF   x9D
41E2:  CLRF   x9E
41E4:  CLRF   x9F
41E6:  CLRF   xA0
41E8:  CLRF   xA1
41EA:  CLRF   xA2
41EC:  CLRF   xA3
41EE:  CLRF   xA4
41F0:  CLRF   xA5
41F2:  CLRF   xA6
41F4:  CLRF   xA7
41F6:  CLRF   xA8
41F8:  CLRF   xA9
41FA:  CLRF   xAA
41FC:  CLRF   xAB
41FE:  CLRF   xAC
4200:  CLRF   xAD
4202:  CLRF   xAE
4204:  CLRF   xAF
4206:  CLRF   xB0
4208:  CLRF   xB1
420A:  CLRF   xB2
420C:  CLRF   xB3
420E:  CLRF   xB4
4210:  CLRF   xB5
4212:  CLRF   xB6
4214:  CLRF   xB7
4216:  CLRF   xB8
4218:  CLRF   xB9
421A:  CLRF   xBA
421C:  CLRF   xBB
421E:  CLRF   xBC
4220:  CLRF   xBD
4222:  CLRF   xBE
4224:  CLRF   xBF
4226:  CLRF   xC0
4228:  CLRF   xC1
422A:  CLRF   xC2
422C:  CLRF   xC3
422E:  CLRF   xC4
4230:  CLRF   xC5
4232:  CLRF   xC6
4234:  CLRF   xC7
4236:  CLRF   xC8
4238:  CLRF   xC9
423A:  CLRF   xCA
423C:  CLRF   xCB
423E:  CLRF   xCC
4240:  CLRF   xCD
4242:  CLRF   xCE
4244:  CLRF   xCF
4246:  CLRF   xD0
4248:  CLRF   xD1
424A:  CLRF   xD2
424C:  CLRF   xD3
424E:  CLRF   xD4
4250:  CLRF   xD5
4252:  CLRF   xD6
4254:  CLRF   xD7
4256:  CLRF   xD8
4258:  CLRF   xD9
425A:  CLRF   xDA
425C:  CLRF   xDB
425E:  CLRF   xDC
4260:  CLRF   xDD
4262:  CLRF   xDE
4264:  CLRF   xDF
4266:  CLRF   xE0
4268:  CLRF   xE1
426A:  CLRF   xE2
426C:  CLRF   xE3
426E:  CLRF   xE4
4270:  CLRF   xE5
4272:  CLRF   xE6
4274:  CLRF   xE7
4276:  CLRF   xE8
4278:  CLRF   xE9
427A:  CLRF   xEA
427C:  CLRF   xEB
427E:  CLRF   xEC
4280:  CLRF   xED
4282:  CLRF   xEE
4284:  CLRF   xEF
4286:  CLRF   xF0
4288:  CLRF   xF1
428A:  CLRF   xF2
428C:  CLRF   xF3
428E:  CLRF   xF4
4290:  CLRF   xF5
4292:  CLRF   xF6
4294:  CLRF   xF7
4296:  CLRF   xF8
4298:  CLRF   xF9
429A:  CLRF   xFA
429C:  CLRF   xFB
429E:  CLRF   xFC
42A0:  CLRF   xFD
42A2:  CLRF   xFE
42A4:  CLRF   xFF
42A6:  MOVLB  1
42A8:  CLRF   x00
42AA:  CLRF   x01
42AC:  CLRF   x02
42AE:  CLRF   x03
42B0:  CLRF   x04
42B2:  CLRF   x05
42B4:  CLRF   x06
42B6:  CLRF   x07
42B8:  CLRF   x08
42BA:  CLRF   x09
42BC:  CLRF   x0A
42BE:  CLRF   x0B
42C0:  CLRF   x0C
42C2:  CLRF   x0D
42C4:  CLRF   x0E
42C6:  CLRF   x0F
42C8:  CLRF   x10
42CA:  CLRF   x11
42CC:  CLRF   x12
42CE:  CLRF   x13
42D0:  CLRF   x14
42D2:  CLRF   x15
42D4:  CLRF   x16
42D6:  CLRF   x17
42D8:  CLRF   x18
42DA:  CLRF   x19
42DC:  CLRF   x1A
42DE:  CLRF   x1B
42E0:  CLRF   x1C
42E2:  CLRF   x1D
42E4:  CLRF   x1E
42E6:  CLRF   x1F
42E8:  CLRF   x20
42EA:  CLRF   x21
42EC:  CLRF   x22
42EE:  CLRF   x23
42F0:  CLRF   x24
42F2:  CLRF   x25
42F4:  CLRF   x26
42F6:  CLRF   x27
42F8:  CLRF   x28
42FA:  CLRF   x29
42FC:  CLRF   x2A
42FE:  CLRF   x2B
4300:  CLRF   x2C
4302:  CLRF   x2D
4304:  CLRF   x2E
4306:  CLRF   x2F
4308:  CLRF   x30
430A:  CLRF   x31
430C:  CLRF   x32
430E:  CLRF   x33
4310:  CLRF   x34
4312:  CLRF   x35
4314:  CLRF   x36
4316:  CLRF   x37
4318:  CLRF   x38
431A:  CLRF   x39
431C:  CLRF   x3A
431E:  CLRF   x3B
4320:  CLRF   x3C
4322:  CLRF   x3D
4324:  CLRF   x3E
4326:  CLRF   x3F
4328:  CLRF   x40
432A:  CLRF   x41
432C:  CLRF   x42
432E:  CLRF   x43
4330:  CLRF   x44
4332:  CLRF   x45
4334:  CLRF   x46
4336:  CLRF   x47
4338:  CLRF   x48
433A:  CLRF   x49
433C:  CLRF   x4A
433E:  CLRF   x4B
4340:  CLRF   x4C
4342:  CLRF   x4D
4344:  CLRF   x4E
4346:  CLRF   x4F
4348:  CLRF   x50
434A:  CLRF   x51
434C:  CLRF   x52
434E:  CLRF   x53
4350:  CLRF   x54
4352:  CLRF   x55
4354:  CLRF   x56
4356:  CLRF   x57
4358:  CLRF   x58
435A:  CLRF   x59
435C:  CLRF   x5A
435E:  CLRF   x5B
4360:  CLRF   x5C
4362:  CLRF   x5D
4364:  CLRF   x5E
4366:  CLRF   x5F
4368:  CLRF   x60
436A:  CLRF   x61
436C:  CLRF   x62
436E:  CLRF   x63
4370:  CLRF   x64
4372:  CLRF   x65
4374:  CLRF   x66
4376:  CLRF   x67
4378:  CLRF   x68
437A:  CLRF   x69
437C:  CLRF   x6A
437E:  CLRF   x6B
4380:  CLRF   x6C
4382:  CLRF   x6D
4384:  CLRF   x6E
4386:  CLRF   x6F
4388:  CLRF   x70
438A:  CLRF   x71
438C:  CLRF   x72
438E:  CLRF   x73
4390:  CLRF   x74
4392:  CLRF   x75
4394:  CLRF   x76
4396:  CLRF   x77
4398:  CLRF   x78
439A:  CLRF   x79
439C:  CLRF   x7A
439E:  CLRF   x7B
43A0:  CLRF   x7C
43A2:  CLRF   x7D
43A4:  CLRF   x7E
43A6:  CLRF   x7F
43A8:  CLRF   x80
43AA:  CLRF   x81
43AC:  CLRF   x82
43AE:  CLRF   x83
43B0:  CLRF   x84
43B2:  CLRF   x85
43B4:  CLRF   x86
43B6:  CLRF   x87
43B8:  CLRF   x88
43BA:  CLRF   x89
43BC:  CLRF   x8A
43BE:  CLRF   x8B
43C0:  CLRF   x8C
43C2:  CLRF   x8D
43C4:  CLRF   x8E
43C6:  CLRF   x8F
43C8:  CLRF   x90
43CA:  CLRF   x91
43CC:  CLRF   x92
43CE:  CLRF   x93
43D0:  CLRF   x94
43D2:  CLRF   x95
43D4:  CLRF   x96
43D6:  CLRF   x97
43D8:  CLRF   x98
43DA:  CLRF   x99
43DC:  CLRF   x9A
43DE:  CLRF   x9B
43E0:  CLRF   x9C
43E2:  CLRF   x9D
43E4:  CLRF   x9E
43E6:  CLRF   x9F
43E8:  CLRF   xA0
43EA:  CLRF   xA1
43EC:  CLRF   xA2
43EE:  CLRF   xA3
43F0:  CLRF   xA4
43F2:  CLRF   xA5
43F4:  CLRF   xA6
43F6:  CLRF   xA7
43F8:  CLRF   xA8
43FA:  CLRF   xA9
43FC:  CLRF   xAA
43FE:  CLRF   xAB
4400:  CLRF   xAC
4402:  CLRF   xAD
4404:  CLRF   xAE
4406:  CLRF   xAF
4408:  CLRF   xB0
440A:  CLRF   xB1
440C:  CLRF   xB2
440E:  CLRF   xB3
4410:  CLRF   xB4
4412:  CLRF   xB5
4414:  CLRF   xB6
4416:  CLRF   xB7
4418:  CLRF   xB8
441A:  CLRF   xB9
441C:  CLRF   xBA
441E:  CLRF   xBB
4420:  CLRF   xBC
4422:  CLRF   xBD
4424:  CLRF   xBE
4426:  CLRF   xBF
4428:  CLRF   xC0
442A:  CLRF   xC1
442C:  CLRF   xC2
442E:  CLRF   xC3
4430:  CLRF   xC4
4432:  CLRF   xC5
4434:  CLRF   xC6
4436:  CLRF   xC7
4438:  CLRF   xC8
443A:  CLRF   xC9
443C:  CLRF   xCA
443E:  CLRF   xCB
4440:  CLRF   xCC
4442:  CLRF   xCD
4444:  CLRF   xCE
4446:  CLRF   xCF
4448:  CLRF   xD0
444A:  CLRF   xD1
444C:  CLRF   xD2
444E:  CLRF   xD3
4450:  CLRF   xD4
4452:  CLRF   xD5
4454:  CLRF   xD6
4456:  CLRF   xD7
4458:  CLRF   xD8
445A:  CLRF   xD9
445C:  CLRF   xDA
445E:  CLRF   xDB
4460:  CLRF   xDC
4462:  CLRF   xDD
4464:  CLRF   xDE
4466:  CLRF   xDF
4468:  CLRF   xE0
446A:  CLRF   xE1
446C:  CLRF   xE2
446E:  CLRF   xE3
4470:  CLRF   xE4
4472:  CLRF   xE5
4474:  CLRF   xE6
4476:  CLRF   xE7
4478:  CLRF   xE8
447A:  CLRF   xE9
447C:  CLRF   xEA
447E:  CLRF   xEB
4480:  CLRF   xEC
4482:  CLRF   xED
4484:  CLRF   xEE
4486:  CLRF   xEF
4488:  CLRF   xF0
448A:  CLRF   xF1
448C:  CLRF   xF2
448E:  CLRF   xF3
4490:  CLRF   xF4
4492:  CLRF   xF5
4494:  CLRF   xF6
4496:  CLRF   xF7
4498:  CLRF   xF8
449A:  CLRF   xF9
449C:  CLRF   xFA
449E:  CLRF   xFB
44A0:  CLRF   xFC
44A2:  CLRF   xFD
44A4:  CLRF   xFE
44A6:  CLRF   xFF
44A8:  MOVLB  2
44AA:  CLRF   x00
44AC:  CLRF   x01
44AE:  CLRF   x02
44B0:  CLRF   x03
44B2:  CLRF   x04
44B4:  CLRF   x05
44B6:  CLRF   x06
44B8:  CLRF   x07
44BA:  CLRF   x08
44BC:  CLRF   x09
44BE:  CLRF   x0A
44C0:  CLRF   x0B
44C2:  CLRF   x0C
44C4:  CLRF   x0D
44C6:  CLRF   x0E
44C8:  CLRF   x0F
44CA:  CLRF   x10
44CC:  CLRF   x11
44CE:  CLRF   x12
44D0:  CLRF   x13
44D2:  CLRF   x14
44D4:  CLRF   x15
44D6:  CLRF   x16
44D8:  CLRF   x17
44DA:  CLRF   x18
44DC:  CLRF   x19
44DE:  CLRF   x1A
44E0:  CLRF   x1B
44E2:  CLRF   x1C
44E4:  BCF    x1D.0
44E6:  CLRF   x1E
44E8:  CLRF   x1F
44EA:  CLRF   x20
44EC:  CLRF   x21
44EE:  CLRF   x22
44F0:  CLRF   x23
44F2:  CLRF   x24
44F4:  CLRF   x25
44F6:  CLRF   x26
44F8:  CLRF   x27
44FA:  CLRF   x28
44FC:  CLRF   x29
44FE:  CLRF   x2A
4500:  CLRF   x2B
4502:  CLRF   x2C
4504:  CLRF   x2D
4506:  CLRF   x2E
4508:  MOVLW  B8
450A:  MOVWF  x2F
450C:  MOVLW  0B
450E:  MOVWF  x30
4510:  MOVLW  01
4512:  MOVWF  x31
4514:  CLRF   x32
4516:  CLRF   x33
4518:  CLRF   x34
451A:  MOVLW  F0
451C:  MOVWF  x35
451E:  MOVLW  D2
4520:  MOVWF  x36
4522:  MOVLW  02
4524:  MOVWF  x37
....................    tGD_UINT32         mainLoopCycles = 0;
4526:  CLRF   x38
4528:  CLRF   x39
452A:  CLRF   x3A
452C:  CLRF   x3B
....................    tGD_UINT16         rxLoopCounter = 0;
452E:  CLRF   x3C
4530:  CLRF   x3D
....................    tsGD_CANPACKET     pkt;
....................    tGD_UINT8          eventSet = 0;
4532:  CLRF   x4A
4534:  BSF    FD1.0
....................    OSCCON = 0x40; // DEBUG
4536:  MOVLW  40
4538:  MOVWF  FD3
....................    RCON = 0x5F;  // DEBUG
453A:  MOVLW  5F
453C:  MOVWF  FD0
PostPosted: Fri Jun 13, 2008 3:59 pm     Reply with quote
If you have global variables and you declare them as 'static', then
the compiler will clear them.
The CCS manual says:
static
Variable is globally active and initialized to 0.
