cparsons
| Watchdog reset, effect on I/O pin & ZERO_FILL |
Posted: Fri Jun 13, 2008 9:19 am |
compiler version: PCWH V4.070
I'm using one of the port D PIC18F4580 pins to control the active-low reset line of another peripheral.
In the case that the PIC resets due to a watchdog timeout I don't want the other peripheral also being reset - I'd like the pin to stay high.
The details of the PIC register values after a soft reset seem to indicate the Port D pins will be unchanged.
If I look at the pin with scope during a watchdog reset I see the pin voltage dip down to 1.9V over a period of 200us before going back up to the 3.3V, the high voltage.
If I create a much smaller program that configures a few registers then causes a watchdog reset then the voltage dip is of the order of a few microvolts over 15us.
If I compare the two .lst files I see that the larger program has about 500 CLRF instructions before the main() function instructions, presumably clearing memory and registers. The smaller program uses much less RAM so only has a couple of CLRF instructions before main().
I've read the documentation, and see the #ZERO_FILL compiler directive. I can't find anywhere in my code where I have included this directive, nor can I find an option for it in the IDE.
- Can anyone see why the CLRF instructions would have a bearing on the pin during a reset?
- If not, are there any other factors that influence the voltage on the pin through a reset?
- Is ZERO_FILL enabled by default on some versions of the compiler? If so, is there a way to turn it off?
Thank you
Chris Parsons
Here is the first instructions of the short program with the very ouput pin voltage dip:
CCS PCH C Compiler, Version 4.070, 41847 13-Jun-08 14:31
Filename: ResetPinTest.lst
ROM used: 490 bytes (1%)
Largest free fragment is 32278
RAM used: 10 (1%) at main() level
13 (1%) worst case
Stack: 1 locations
0000: GOTO 00D4
<---snip--->
.................... #use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)
.................... #FUSES WDT512 //Watch Dog Timer uses 1:256 Postscale
.................... #FUSES EC_IO //External clock
.................... #FUSES NOPROTECT //Code not protected from reading
.................... #FUSES BROWNOUT //Reset when brownout detected
.................... #FUSES BORV28 //Brownout reset at 2.8V
.................... #FUSES NOPUT //No Power Up Timer
.................... #FUSES NOCPD //No EE protection
.................... #FUSES STVREN //Stack full/underflow will cause reset
.................... #FUSES NODEBUG //Debug mode for use with ICD
.................... #FUSES NOLVP //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
.................... #FUSES NOWRT //Program memory not write protected
.................... #FUSES NOWRTD //Data EEPROM not write protected
.................... #FUSES NOIESO //Internal External Switch Over mode disabled
.................... #FUSES NOFCMEN //Fail-safe clock monitor disabled
.................... #FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
.................... #FUSES BBSIZ2K //2K words Boot Block size
.................... #FUSES NOWRTC //configuration not registers write protected
.................... #FUSES NOWRTB //Boot block not write protected
.................... #FUSES NOEBTR //Memory not protected from table reads
.................... #FUSES NOEBTRB //Boot block not protected from table reads
.................... #FUSES NOCPB //No Boot Block code protection
.................... #FUSES LPT1OSC //Timer1 configured for low-power operation
.................... #FUSES MCLR //Master Clear pin enabled
.................... #FUSES NOXINST //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
.................... #bit RCON_POR = 0x0FD0.1
.................... #define PIN_PPC750FL_HARD_RESET (PIN_D7)
00D4: CLRF FF8
00D6: BCF FD0.7
00D8: CLRF FEA
00DA: CLRF FE9
00DC: BCF FB8.3
00DE: MOVLW 17
00E0: MOVWF FAF
00E2: MOVLW A2
00E4: MOVWF FAC
00E6: MOVLW 90
00E8: MOVWF FAB
00EA: MOVF FC1,W
00EC: ANDLW C0
00EE: IORLW 0F
00F0: MOVWF FC1
00F2: MOVLW 07
00F4: MOVWF FB4
00F6: CLRF 05
.................... long int count;
.................... setup_wdt(WDT_ON);
00F8: BSF FD1.0
.................... if (RCON_POR == 0)
00FA: BTFSC FD0.1
00FC: BRA 0102
.................... hardReset = 1;
00FE: MOVLW 01
and this is the equivalent code for the normal program
CCS PCH C Compiler, Version 4.070, 41847 13-Jun-08 14:36
Filename: PMN_main.lst
ROM used: 18144 bytes (55%)
Largest free fragment is 14620
RAM used: 589 (38%) at main() level
663 (43%) worst case
Stack: 7 worst case (5 in main + 2 for interrupts)
0000: GOTO 40DA
<---snip - fuse configuration should be the same as above --->
.................... void main ()
40DA: CLRF FF8
40DC: BCF FD0.7
40DE: BSF 0D.7
40E0: CLRF FEA
40E2: CLRF FE9
40E4: BCF FB8.3
40E6: MOVLW 17
40E8: MOVWF FAF
40EA: MOVLW A2
40EC: MOVWF FAC
40EE: MOVLW 90
40F0: MOVWF FAB
40F2: MOVF FC1,W
40F4: ANDLW C0
40F6: IORLW 0F
40F8: MOVWF FC1
40FA: MOVLW 07
40FC: MOVWF FB4
40FE: MOVLW 40
4100: MOVWF 2B
4102: MOVLW 42
4104: MOVWF 2C
4106: MOVLW 0F
4108: MOVWF 2D
410A: CLRF 2E
410C: CLRF 33
410E: CLRF 34
4110: CLRF 35
4112: CLRF 36
4114: CLRF 37
4116: CLRF 38
4118: CLRF 39
411A: CLRF 3A
411C: CLRF 3B
411E: CLRF 3C
4120: CLRF 3D
4122: CLRF 3E
4124: CLRF 3F
4126: CLRF 40
4128: CLRF 41
412A: CLRF 42
412C: CLRF 43
412E: CLRF 44
4130: CLRF 45
4132: CLRF 46
4134: CLRF 47
4136: CLRF 48
4138: CLRF 49
413A: CLRF 4A
413C: CLRF 4B
413E: CLRF 4C
4140: CLRF 4D
4142: CLRF 4E
4144: CLRF 4F
4146: CLRF 50
4148: CLRF 51
414A: CLRF 52
414C: CLRF 53
414E: CLRF 54
4150: CLRF 55
4152: CLRF 56
4154: CLRF 57
4156: CLRF 58
4158: CLRF 59
415A: CLRF 5A
415C: CLRF 5B
415E: CLRF 5C
4160: CLRF 5D
4162: CLRF 5E
4164: CLRF 5F
4166: CLRF x60
4168: CLRF x61
416A: CLRF x62
416C: CLRF x63
416E: CLRF x64
4170: CLRF x65
4172: CLRF x66
4174: CLRF x67
4176: CLRF x68
4178: CLRF x69
417A: CLRF x6A
417C: CLRF x6B
417E: CLRF x6C
4180: CLRF x6D
4182: CLRF x6E
4184: CLRF x6F
4186: CLRF x70
4188: CLRF x71
418A: CLRF x72
418C: CLRF x73
418E: CLRF x74
4190: CLRF x75
4192: CLRF x76
4194: CLRF x77
4196: CLRF x78
4198: CLRF x79
419A: CLRF x7A
419C: CLRF x7B
419E: CLRF x7C
41A0: CLRF x7D
41A2: CLRF x7E
41A4: CLRF x7F
41A6: CLRF x80
41A8: CLRF x81
41AA: CLRF x82
41AC: CLRF x83
41AE: CLRF x84
41B0: CLRF x85
41B2: CLRF x86
41B4: CLRF x87
41B6: CLRF x88
41B8: CLRF x89
41BA: CLRF x8A
41BC: CLRF x8B
41BE: CLRF x8C
41C0: CLRF x8D
41C2: CLRF x8E
41C4: CLRF x8F
41C6: CLRF x90
41C8: CLRF x91
41CA: CLRF x92
41CC: CLRF x93
41CE: CLRF x94
41D0: CLRF x95
41D2: CLRF x96
41D4: CLRF x97
41D6: CLRF x98
41D8: CLRF x99
41DA: CLRF x9A
41DC: CLRF x9B
41DE: CLRF x9C
41E0: CLRF x9D
41E2: CLRF x9E
41E4: CLRF x9F
41E6: CLRF xA0
41E8: CLRF xA1
41EA: CLRF xA2
41EC: CLRF xA3
41EE: CLRF xA4
41F0: CLRF xA5
41F2: CLRF xA6
41F4: CLRF xA7
41F6: CLRF xA8
41F8: CLRF xA9
41FA: CLRF xAA
41FC: CLRF xAB
41FE: CLRF xAC
4200: CLRF xAD
4202: CLRF xAE
4204: CLRF xAF
4206: CLRF xB0
4208: CLRF xB1
420A: CLRF xB2
420C: CLRF xB3
420E: CLRF xB4
4210: CLRF xB5
4212: CLRF xB6
4214: CLRF xB7
4216: CLRF xB8
4218: CLRF xB9
421A: CLRF xBA
421C: CLRF xBB
421E: CLRF xBC
4220: CLRF xBD
4222: CLRF xBE
4224: CLRF xBF
4226: CLRF xC0
4228: CLRF xC1
422A: CLRF xC2
422C: CLRF xC3
422E: CLRF xC4
4230: CLRF xC5
4232: CLRF xC6
4234: CLRF xC7
4236: CLRF xC8
4238: CLRF xC9
423A: CLRF xCA
423C: CLRF xCB
423E: CLRF xCC
4240: CLRF xCD
4242: CLRF xCE
4244: CLRF xCF
4246: CLRF xD0
4248: CLRF xD1
424A: CLRF xD2
424C: CLRF xD3
424E: CLRF xD4
4250: CLRF xD5
4252: CLRF xD6
4254: CLRF xD7
4256: CLRF xD8
4258: CLRF xD9
425A: CLRF xDA
425C: CLRF xDB
425E: CLRF xDC
4260: CLRF xDD
4262: CLRF xDE
4264: CLRF xDF
4266: CLRF xE0
4268: CLRF xE1
426A: CLRF xE2
426C: CLRF xE3
426E: CLRF xE4
4270: CLRF xE5
4272: CLRF xE6
4274: CLRF xE7
4276: CLRF xE8
4278: CLRF xE9
427A: CLRF xEA
427C: CLRF xEB
427E: CLRF xEC
4280: CLRF xED
4282: CLRF xEE
4284: CLRF xEF
4286: CLRF xF0
4288: CLRF xF1
428A: CLRF xF2
428C: CLRF xF3
428E: CLRF xF4
4290: CLRF xF5
4292: CLRF xF6
4294: CLRF xF7
4296: CLRF xF8
4298: CLRF xF9
429A: CLRF xFA
429C: CLRF xFB
429E: CLRF xFC
42A0: CLRF xFD
42A2: CLRF xFE
42A4: CLRF xFF
42A6: MOVLB 1
42A8: CLRF x00
42AA: CLRF x01
42AC: CLRF x02
42AE: CLRF x03
42B0: CLRF x04
42B2: CLRF x05
42B4: CLRF x06
42B6: CLRF x07
42B8: CLRF x08
42BA: CLRF x09
42BC: CLRF x0A
42BE: CLRF x0B
42C0: CLRF x0C
42C2: CLRF x0D
42C4: CLRF x0E
42C6: CLRF x0F
42C8: CLRF x10
42CA: CLRF x11
42CC: CLRF x12
42CE: CLRF x13
42D0: CLRF x14
42D2: CLRF x15
42D4: CLRF x16
42D6: CLRF x17
42D8: CLRF x18
42DA: CLRF x19
42DC: CLRF x1A
42DE: CLRF x1B
42E0: CLRF x1C
42E2: CLRF x1D
42E4: CLRF x1E
42E6: CLRF x1F
42E8: CLRF x20
42EA: CLRF x21
42EC: CLRF x22
42EE: CLRF x23
42F0: CLRF x24
42F2: CLRF x25
42F4: CLRF x26
42F6: CLRF x27
42F8: CLRF x28
42FA: CLRF x29
42FC: CLRF x2A
42FE: CLRF x2B
4300: CLRF x2C
4302: CLRF x2D
4304: CLRF x2E
4306: CLRF x2F
4308: CLRF x30
430A: CLRF x31
430C: CLRF x32
430E: CLRF x33
4310: CLRF x34
4312: CLRF x35
4314: CLRF x36
4316: CLRF x37
4318: CLRF x38
431A: CLRF x39
431C: CLRF x3A
431E: CLRF x3B
4320: CLRF x3C
4322: CLRF x3D
4324: CLRF x3E
4326: CLRF x3F
4328: CLRF x40
432A: CLRF x41
432C: CLRF x42
432E: CLRF x43
4330: CLRF x44
4332: CLRF x45
4334: CLRF x46
4336: CLRF x47
4338: CLRF x48
433A: CLRF x49
433C: CLRF x4A
433E: CLRF x4B
4340: CLRF x4C
4342: CLRF x4D
4344: CLRF x4E
4346: CLRF x4F
4348: CLRF x50
434A: CLRF x51
434C: CLRF x52
434E: CLRF x53
4350: CLRF x54
4352: CLRF x55
4354: CLRF x56
4356: CLRF x57
4358: CLRF x58
435A: CLRF x59
435C: CLRF x5A
435E: CLRF x5B
4360: CLRF x5C
4362: CLRF x5D
4364: CLRF x5E
4366: CLRF x5F
4368: CLRF x60
436A: CLRF x61
436C: CLRF x62
436E: CLRF x63
4370: CLRF x64
4372: CLRF x65
4374: CLRF x66
4376: CLRF x67
4378: CLRF x68
437A: CLRF x69
437C: CLRF x6A
437E: CLRF x6B
4380: CLRF x6C
4382: CLRF x6D
4384: CLRF x6E
4386: CLRF x6F
4388: CLRF x70
438A: CLRF x71
438C: CLRF x72
438E: CLRF x73
4390: CLRF x74
4392: CLRF x75
4394: CLRF x76
4396: CLRF x77
4398: CLRF x78
439A: CLRF x79
439C: CLRF x7A
439E: CLRF x7B
43A0: CLRF x7C
43A2: CLRF x7D
43A4: CLRF x7E
43A6: CLRF x7F
43A8: CLRF x80
43AA: CLRF x81
43AC: CLRF x82
43AE: CLRF x83
43B0: CLRF x84
43B2: CLRF x85
43B4: CLRF x86
43B6: CLRF x87
43B8: CLRF x88
43BA: CLRF x89
43BC: CLRF x8A
43BE: CLRF x8B
43C0: CLRF x8C
43C2: CLRF x8D
43C4: CLRF x8E
43C6: CLRF x8F
43C8: CLRF x90
43CA: CLRF x91
43CC: CLRF x92
43CE: CLRF x93
43D0: CLRF x94
43D2: CLRF x95
43D4: CLRF x96
43D6: CLRF x97
43D8: CLRF x98
43DA: CLRF x99
43DC: CLRF x9A
43DE: CLRF x9B
43E0: CLRF x9C
43E2: CLRF x9D
43E4: CLRF x9E
43E6: CLRF x9F
43E8: CLRF xA0
43EA: CLRF xA1
43EC: CLRF xA2
43EE: CLRF xA3
43F0: CLRF xA4
43F2: CLRF xA5
43F4: CLRF xA6
43F6: CLRF xA7
43F8: CLRF xA8
43FA: CLRF xA9
43FC: CLRF xAA
43FE: CLRF xAB
4400: CLRF xAC
4402: CLRF xAD
4404: CLRF xAE
4406: CLRF xAF
4408: CLRF xB0
440A: CLRF xB1
440C: CLRF xB2
440E: CLRF xB3
4410: CLRF xB4
4412: CLRF xB5
4414: CLRF xB6
4416: CLRF xB7
4418: CLRF xB8
441A: CLRF xB9
441C: CLRF xBA
441E: CLRF xBB
4420: CLRF xBC
4422: CLRF xBD
4424: CLRF xBE
4426: CLRF xBF
4428: CLRF xC0
442A: CLRF xC1
442C: CLRF xC2
442E: CLRF xC3
4430: CLRF xC4
4432: CLRF xC5
4434: CLRF xC6
4436: CLRF xC7
4438: CLRF xC8
443A: CLRF xC9
443C: CLRF xCA
443E: CLRF xCB
4440: CLRF xCC
4442: CLRF xCD
4444: CLRF xCE
4446: CLRF xCF
4448: CLRF xD0
444A: CLRF xD1
444C: CLRF xD2
444E: CLRF xD3
4450: CLRF xD4
4452: CLRF xD5
4454: CLRF xD6
4456: CLRF xD7
4458: CLRF xD8
445A: CLRF xD9
445C: CLRF xDA
445E: CLRF xDB
4460: CLRF xDC
4462: CLRF xDD
4464: CLRF xDE
4466: CLRF xDF
4468: CLRF xE0
446A: CLRF xE1
446C: CLRF xE2
446E: CLRF xE3
4470: CLRF xE4
4472: CLRF xE5
4474: CLRF xE6
4476: CLRF xE7
4478: CLRF xE8
447A: CLRF xE9
447C: CLRF xEA
447E: CLRF xEB
4480: CLRF xEC
4482: CLRF xED
4484: CLRF xEE
4486: CLRF xEF
4488: CLRF xF0
448A: CLRF xF1
448C: CLRF xF2
448E: CLRF xF3
4490: CLRF xF4
4492: CLRF xF5
4494: CLRF xF6
4496: CLRF xF7
4498: CLRF xF8
449A: CLRF xF9
449C: CLRF xFA
449E: CLRF xFB
44A0: CLRF xFC
44A2: CLRF xFD
44A4: CLRF xFE
44A6: CLRF xFF
44A8: MOVLB 2
44AA: CLRF x00
44AC: CLRF x01
44AE: CLRF x02
44B0: CLRF x03
44B2: CLRF x04
44B4: CLRF x05
44B6: CLRF x06
44B8: CLRF x07
44BA: CLRF x08
44BC: CLRF x09
44BE: CLRF x0A
44C0: CLRF x0B
44C2: CLRF x0C
44C4: CLRF x0D
44C6: CLRF x0E
44C8: CLRF x0F
44CA: CLRF x10
44CC: CLRF x11
44CE: CLRF x12
44D0: CLRF x13
44D2: CLRF x14
44D4: CLRF x15
44D6: CLRF x16
44D8: CLRF x17
44DA: CLRF x18
44DC: CLRF x19
44DE: CLRF x1A
44E0: CLRF x1B
44E2: CLRF x1C
44E4: BCF x1D.0
44E6: CLRF x1E
44E8: CLRF x1F
44EA: CLRF x20
44EC: CLRF x21
44EE: CLRF x22
44F0: CLRF x23
44F2: CLRF x24
44F4: CLRF x25
44F6: CLRF x26
44F8: CLRF x27
44FA: CLRF x28
44FC: CLRF x29
44FE: CLRF x2A
4500: CLRF x2B
4502: CLRF x2C
4504: CLRF x2D
4506: CLRF x2E
4508: MOVLW B8
450A: MOVWF x2F
450C: MOVLW 0B
450E: MOVWF x30
4510: MOVLW 01
4512: MOVWF x31
4514: CLRF x32
4516: CLRF x33
4518: CLRF x34
451A: MOVLW F0
451C: MOVWF x35
451E: MOVLW D2
4520: MOVWF x36
4522: MOVLW 02
4524: MOVWF x37
.................... tGD_UINT32 mainLoopCycles = 0;
4526: CLRF x38
4528: CLRF x39
452A: CLRF x3A
452C: CLRF x3B
.................... tGD_UINT16 rxLoopCounter = 0;
452E: CLRF x3C
4530: CLRF x3D
.................... tsGD_CANPACKET pkt;
.................... tGD_UINT8 eventSet = 0;
4532: CLRF x4A
4534: BSF FD1.0
.................... OSCCON = 0x40; // DEBUG
4536: MOVLW 40
4538: MOVWF FD3
.................... RCON = 0x5F; // DEBUG
453A: MOVLW 5F
453C: MOVWF FD0
Posted: Fri Jun 13, 2008 3:59 pm |
If you have global variables and you declare them as 'static', then
the compiler will clear them.
The CCS manual says:
| Quote: | static
Variable is globally active and initialized to 0. |
