I2C - reading from slave problem
sv_shady
PostPosted: Sun Jun 15, 2008 4:31 am     Reply with quote
Hi, this is probably my third topic on i2c problems... I have no problems with writing to slave, but now I have to read from slave and of course it doesn't work...
The master is PIC18F4620 and here is its source code:
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES NOEBTR                   //Memory not protected from table reads
#FUSES NOCPB                    //No Boot Block code protection
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOWRTC                   //configuration not registers write protected
#FUSES NOWRTB                   //Boot block not write protected
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES NOPBADEN                 //PORTB pins are configured as digital I/O on RESET
#FUSES LPT1OSC                  //Timer1 configured for low-power operation
#FUSES MCLR                     //Master Clear pin enabled
#use delay(clock=40000000)
#use i2c(Master,sda=PIN_C4,scl=PIN_C3, force_hw)
#define LED       PIN_B5
#define I2C_SCL   PIN_C3
#define I2C_SDA   PIN_C4
#define XBEE       0xAA
#define MOTORS      0XBA
#define WRITE      0x00
#define READ      0x01
#define SEND_DATA      0x01
// n - number of bytes
// n bytes
void Init()
   setup_psp(PSP_DISABLED);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
int value_X = 0, value_Y = 0;
 Init();
   i2c_start();
   i2c_write(XBEE|READ);
   value_X = i2c_read();
   value_Y = i2c_read(0);
   i2c_stop();
   /*i2c_start();
   i2c_write(XBEE|WRITE);
   i2c_write(SEND_DATA);
   i2c_write(0x02);
   i2c_write(0x15);
   i2c_write(0x20);
   i2c_stop();*/
The slave is PIC16F88, and the source:
#include <16F88.h>
#device adc=8
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES PUT                      //Power Up Timer
#FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOCPD                    //No EE protection
#FUSES NOWRT                    //Program memory not write protected
#FUSES NODEBUG                  //No Debug mode for ICD
#FUSES NOPROTECT                //Code not protected from reading
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#use rs232(baud = 9600, parity = N, xmit = PIN_B5, rcv = PIN_B2, bits = 8)
#use i2c(Slave, sda=PIN_B1, scl=PIN_B4, address = 0xAA, force_hw)
#define I2C_SDA   PIN_B1
#define I2C_SCL   PIN_B4
#define LED          PIN_B0
//-------------i2c instructions-------------------------------------------------
int c;
int value_X = 128, value_Y = 128;
int instruction = 0;
int nbytes = 0;
int data[16] = {0};
int data_indx = 0;
#int_SSP
void  SSP_isr(void)
   int incoming = 0, state;
   output_bit(LED, 1);
   state = i2c_isr_state(1);
   if(0 < state && state < 0x80)
      incoming = i2c_read();
      if(state == 1) instruction = incoming;
      if(state >= 2)
           switch(instruction)
            case SEND_DATA:
               if(state == 2)
                  nbytes = incoming;
                  data_indx = 0;
               else data[data_indx++] = incoming;
            default:;
   if(state >= 0x80)
      if(state == 0x80) i2c_write(value_X);
      if(state == 0x81) i2c_write(value_Y);
   output_bit(LED, 0);
   setup_adc(ADC_OFF);
   setup_vref(FALSE);
   output_bit(LED, 0);
   enable_interrupts(INT_SSP);
   for(;;)
      if(nbytes == data_indx && nbytes != 0)
         printf("%u%u", data[0], data[1]);
         data_indx = 0;
When the master writes to the slave everything is OK, but when the master is reading from the slave it hangs at the first i2c_read() statement, and the slave hangs at the i2c_write() statement. When this happens the clock is low. I have tried with software i2c functions for the slave and then the master reads 255... Also I have tried with delay times between the master commands, but nothing... I suppose that the slave stretches the clock but have no idea why. I would be thankful for any help or suggestions.
sv_shady
PostPosted: Sat Jun 21, 2008 2:44 am     Reply with quote
Come on guys... I don't think that nobody can help me. After more testin I've found out that the SSPBUF register of the master i set with the value it is supposed to read, but the bit for transmission completion states that the transmission ist finished. I suppoese this is something with ACKs. The Master talks to another PIC18F2520 and it successfully reads and writes to it so the problem is in the 16F88 slave. I am on the verge of writing my i2c routines...
