sv_shady
I2C - reading from slave problem |
Posted: Sun Jun 15, 2008 4:31 am |
Hi, this is probably my third topic on i2c problems... I have no problems with writing to slave, but now I have to read from slave and of course it doesn't work...
The master is PIC18F4620 and here is its source code:
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES LPT1OSC //Timer1 configured for low-power operation
#use delay(clock=40000000)
#use i2c(Master,sda=PIN_C4,scl=PIN_C3, force_hw)
#define LED PIN_B5
#define I2C_SCL PIN_C3
#define I2C_SDA PIN_C4
#define XBEE 0xAA
#define MOTORS 0XBA
#define WRITE 0x00
#define READ 0x01
#define SEND_DATA 0x01
// n - number of bytes
// n bytes
void Init()
setup_psp(PSP_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
int value_X = 0, value_Y = 0;
Init();
i2c_start();
i2c_write(XBEE|READ);
value_X = i2c_read();
value_Y = i2c_read(0);
i2c_stop();
/*i2c_start();
i2c_write(XBEE|WRITE);
i2c_write(SEND_DATA);
i2c_write(0x02);
i2c_write(0x15);
i2c_write(0x20);
i2c_stop();*/
The slave is PIC16F88, and the source:
#include <16F88.h>
#device adc=8
#FUSES HS //High speed Osc (> 4mhz)
#FUSES PUT //Power Up Timer
#use rs232(baud = 9600, parity = N, xmit = PIN_B5, rcv = PIN_B2, bits = 8)
#use i2c(Slave, sda=PIN_B1, scl=PIN_B4, address = 0xAA, force_hw)
#define I2C_SDA PIN_B1
#define I2C_SCL PIN_B4
#define LED PIN_B0
//-------------i2c instructions-------------------------------------------------
int c;
int value_X = 128, value_Y = 128;
int instruction = 0;
int nbytes = 0;
int data[16] = {0};
int data_indx = 0;
#int_SSP
void SSP_isr(void)
int incoming = 0, state;
output_bit(LED, 1);
state = i2c_isr_state(1);
if(0 < state && state < 0x80)
incoming = i2c_read();
if(state == 1) instruction = incoming;
if(state >= 2)
switch(instruction)
case SEND_DATA:
if(state == 2)
nbytes = incoming;
data_indx = 0;
else data[data_indx++] = incoming;
default:;
if(state >= 0x80)
if(state == 0x80) i2c_write(value_X);
if(state == 0x81) i2c_write(value_Y);
output_bit(LED, 0);
setup_adc(ADC_OFF);
setup_vref(FALSE);
output_bit(LED, 0);
enable_interrupts(INT_SSP);
for(;;)
if(nbytes == data_indx && nbytes != 0)
printf("%u%u", data[0], data[1]);
data_indx = 0;
When the master writes to the slave everything is OK, but when the master is reading from the slave it hangs at the first i2c_read() statement, and the slave hangs at the i2c_write() statement. When this happens the clock is low. I have tried with software i2c functions for the slave and then the master reads 255... Also I have tried with delay times between the master commands, but nothing... I suppose that the slave stretches the clock but have no idea why. I would be thankful for any help or suggestions. |
