18F4620 not starting
Franck26
PostPosted: Tue May 20, 2008 3:35 am     Reply with quote
Hello everybody,
I have some problems to start a 18F4620.
Everything is working fine in debug mode, but when I try to make it working without the ICD, it simply not starting...
The config that I use when I'm not in debug mode is the following:
#include <18F4620.h>
//#device ICD=TRUE
#device adc=8
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES NOPROTECT                //Code not protected from reading
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES BORV28                   //Brownout reset at 2.8V
#FUSES PUT                      //Power Up Timer
#FUSES NOCPD                    //No EE protection
//#FUSES DEBUG                    //Debug mode for use with ICD
#FUSES NODEBUG
#FUSES LVP                      //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES NOWRT                    //Program memory not write protected
#FUSES NOCPB                    //No Boot Block code protection
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES NOPBADEN                 //PORTB pins are configured as digital I/O on RESET
#FUSES LPT1OSC                  //Timer1 configured for low-power operation
#FUSES MCLR                     //Master Clear pin enabled
#use delay(clock=8000000)
There is a pull-up resistor of 47k MCLR pin and no external oscillator.
Thanks for any help,
Franck.
RLScott
Re: 18F4620 not starting
PostPosted: Tue May 20, 2008 5:24 am     Reply with quote
What evidence do you have that it is not starting? Did you put a simple infinite loop at the beginning with some output toggle in the loop?
Also, unless you really need it, you should disable LVP. It can cause start-up trouble.
Robert Scott
Real-Time Specialties
Franck26
PostPosted: Tue May 20, 2008 6:11 am     Reply with quote
Thanks RLScott,
You are right, the problem was the LVP.
It's starting fine now.
Thanks,
Franck.
