Franck26
| 18F4620 not starting |
Posted: Tue May 20, 2008 3:35 am |
Hello everybody,
I have some problems to start a 18F4620.
Everything is working fine in debug mode, but when I try to make it working without the ICD, it simply not starting...
The config that I use when I'm not in debug mode is the following:
| Code: | #include <18F4620.h>
//#device ICD=TRUE
#device adc=8
#FUSES BORV28 //Brownout reset at 2.8V
#FUSES PUT //Power Up Timer
//#FUSES DEBUG //Debug mode for use with ICD
#FUSES NODEBUG
#FUSES LVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES LPT1OSC //Timer1 configured for low-power operation
#use delay(clock=8000000) |
There is a pull-up resistor of 47k MCLR pin and no external oscillator.
Thanks for any help,
Franck. |
RLScott
| Re: 18F4620 not starting |
Posted: Tue May 20, 2008 5:24 am |
What evidence do you have that it is not starting? Did you put a simple infinite loop at the beginning with some output toggle in the loop?
Also, unless you really need it, you should disable LVP. It can cause start-up trouble.
Robert Scott
Real-Time Specialties |
Franck26
Posted: Tue May 20, 2008 6:11 am |
Thanks RLScott,
You are right, the problem was the LVP.
It's starting fine now.
Thanks,
Franck. |
