filjoa
PDU encode/decode |
Posted: Wed May 14, 2008 1:34 pm |
Hi
I try encode in PDU mode an string for example "hello word" and I search on this forum but I don't find anything which work..
for example there: http://www.ccsinfo.com/forum/viewtopic.php?t=22619&highlight=pdu
I have this file pduconv.c but it not work with the CCS...
same one know as I change this code for CCS mode?
the result to send "hello word" for my phone in PDU mode with:
service center number: +962100000
mobile phone number: 965542750
is this string:
069169120000F01100099169552457F00000AA0AE8329BFD06DDDF7232
the file which I have is:
#include <string.h>
#include <stdlibm.h> // Contains malloc() function for CCS
//#include <stdio.h>
#define VERSION 0.1
/* Define Non-Printable Characters as a question mark */
#define NPC7 63
#define NPC8 '?'
// Reduced LU table for save ROM usage
int lookup_ascii8to7[]={
NPC7, /* 0 null [NUL] */
NPC7, /* 1 start of heading [SOH] */
NPC7, /* 2 start of text [STX] */
NPC7, /* 3 end of text [ETX] */
NPC7, /* 4 end of transmission [EOT] */
NPC7, /* 5 enquiry [ENQ] */
NPC7, /* 6 acknowledge [ACK] */
NPC7, /* 7 bell [BEL] */
NPC7, /* 8 backspace [BS] */
NPC7, /* 9 horizontal tab [HT] */
10, /* 10 line feed [LF] */
NPC7, /* 11 vertical tab [VT] */
10+256, /* 12 form feed [FF] */
13, /* 13 carriage return [CR] */
NPC7, /* 14 shift out [SO] */
NPC7, /* 15 shift in [SI] */
NPC7, /* 16 data link escape [DLE] */
NPC7, /* 17 device control 1 [DC1] */
NPC7, /* 18 device control 2 [DC2] */
NPC7, /* 19 device control 3 [DC3] */
NPC7, /* 20 device control 4 [DC4] */
NPC7, /* 21 negative acknowledge [NAK] */
NPC7, /* 22 synchronous idle [SYN] */
NPC7, /* 23 end of trans. block [ETB] */
NPC7, /* 24 cancel [CAN] */
NPC7, /* 25 end of medium [EM] */
NPC7, /* 26 substitute [SUB] */
NPC7, /* 27 escape [ESC] */
NPC7, /* 28 file separator [FS] */
NPC7, /* 29 group separator [GS] */
NPC7, /* 30 record separator [RS] */
NPC7, /* 31 unit separator [US] */
32, /* 32 space */
33, /* 33 ! exclamation mark */
34, /* 34 " double quotation mark */
35, /* 35 # number sign */
2, /* 36 $ dollar sign */
37, /* 37 % percent sign */
38, /* 38 & ampersand */
39, /* 39 ' apostrophe */
40, /* 40 ( left parenthesis */
41, /* 41 ) right parenthesis */
42, /* 42 * asterisk */
43, /* 43 + plus sign */
44, /* 44 , comma */
45, /* 45 - hyphen */
46, /* 46 . period */
47, /* 47 / slash, */
48, /* 48 0 digit 0 */
49, /* 49 1 digit 1 */
50, /* 50 2 digit 2 */
51, /* 51 3 digit 3 */
52, /* 52 4 digit 4 */
53, /* 53 5 digit 5 */
54, /* 54 6 digit 6 */
55, /* 55 7 digit 7 */
56, /* 56 8 digit 8 */
57, /* 57 9 digit 9 */
58, /* 58 : colon */
59, /* 59 ; semicolon */
60, /* 60 < less-than sign */
61, /* 61 = equal sign */
62, /* 62 > greater-than sign */
63, /* 63 ? question mark */
0, /* 64 @ commercial at sign */
65, /* 65 A uppercase A */
66, /* 66 B uppercase B */
67, /* 67 C uppercase C */
68, /* 68 D uppercase D */
69, /* 69 E uppercase E */
70, /* 70 F uppercase F */
71, /* 71 G uppercase G */
72, /* 72 H uppercase H */
73, /* 73 I uppercase I */
74, /* 74 J uppercase J */
75, /* 75 K uppercase K */
76, /* 76 L uppercase L */
77, /* 77 M uppercase M */
78, /* 78 N uppercase N */
79, /* 79 O uppercase O */
80, /* 80 P uppercase P */
81, /* 81 Q uppercase Q */
82, /* 82 R uppercase R */
83, /* 83 S uppercase S */
84, /* 84 T uppercase T */
85, /* 85 U uppercase U */
86, /* 86 V uppercase V */
87, /* 87 W uppercase W */
88, /* 88 X uppercase X */
89, /* 89 Y uppercase Y */
90, /* 90 Z uppercase Z */
60+256, /* 91 [ left square bracket */
47+256, /* 92 \ backslash */
62+256, /* 93 ] right square bracket */
20+256, /* 94 ^ circumflex accent */
17, /* 95 _ underscore */
-39, /* 96 ` back apostrophe */
97, /* 97 a lowercase a */
98, /* 98 b lowercase b */
99, /* 99 c lowercase c */
100, /* 100 d lowercase d */
101, /* 101 e lowercase e */
102, /* 102 f lowercase f */
103, /* 103 g lowercase g */
104, /* 104 h lowercase h */
105, /* 105 i lowercase i */
106, /* 106 j lowercase j */
107, /* 107 k lowercase k */
108, /* 108 l lowercase l */
109, /* 109 m lowercase m */
110, /* 110 n lowercase n */
111, /* 111 o lowercase o */
112, /* 112 p lowercase p */
113, /* 113 q lowercase q */
114, /* 114 r lowercase r */
115, /* 115 s lowercase s */
116, /* 116 t lowercase t */
117, /* 117 u lowercase u */
118, /* 118 v lowercase v */
119, /* 119 w lowercase w */
120, /* 120 x lowercase x */
121, /* 121 y lowercase y */
122, /* 122 z lowercase z */
static int convert_ascii_to_7bit(char *ascii, char *a7bit[]) {
int r;
int w;
r=0;
w=0;
/* Allocate sufficient memory for the result string */
*a7bit=malloc(strlen(ascii)*2+1);
while (ascii[r]!=0) {
if ((lookup_ascii8to7[(unsigned char)ascii[r]])<256) {
*a7bit[w++]=abs(lookup_ascii8to7[(unsigned char)ascii[r++]]);
} else {
*a7bit[w++]=27;
*a7bit[w++]=lookup_ascii8to7[(unsigned char)ascii[r++]]-256;
/* Realloc the result array to the correct size */
*a7bit=realloc(*a7bit,w);
return w;
* Convert an ISO-8859-1 ASCII string to an array of PDU-coded bytes
* *ascii The ISO-cleartext to convert
* **pdu Pointer to an array where the pdu-bytes will be stored in, this
* function allocates the neccesary memory for the array
* Use +pdu[] for CCS
* Returns the number of bytes stored in the pdu-array
* Note: Don't forget to free() the pdu-array when you're finished with it.
int ascii_to_pdu(char *ascii, unsigned char *pdu[]) {
int r;
int w;
char *ascii7bit;
int len7bit;
/* Start by converting the ISO-string to a 7bit-string */
len7bit=convert_ascii_to_7bit(ascii,&ascii7bit);
*pdu=malloc(len7bit);
/* Now, we can create a PDU string by packing the 7bit-string */
r=0;
w=0;
while (r<len7bit) {
*pdu[w]=((ascii7bit[r]>>(w%7))&0x7F) | ((ascii7bit[r+1]<<(7-(w%7)))&0xFF);
if ((w%7)==6) r++;
r++;
w++;
free(ascii7bit);
return w;
as I can make an simple program when I have constant string "hello word" and can see them in PDU mode on terminal?
regards |
filjoa
Posted: Wed May 14, 2008 2:09 pm |
Hi
I make this code but it don't write anything and result correct without number is :
hello word=00110000910000AA0AE8329BFD06DDDF7232
#include <18F452.h>
#device adc=8
#FUSES HS //High speed Osc (> 4mhz)
#FUSES NOOSCSEN //Oscillator switching is disabled, main oscillator is source
#FUSES BORV20 //Brownout reset at 2.0V
#use rs232(baud=115200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
code:
#include "teste_PDU.h"
#include "pduconv.c"
#build(reset=0x200)
#build(interrupt=0x208)
#org 0x0000,0x01ff
void bootloader() {
#asm
nop
#endasm
} // Reserve space for the bootloader
int i;
int pdulen;
unsigned char *pdu;
char buffer[];
printf("string PDU: \n\r");
buffer="hello word";
pdulen=ascii_to_pdu(buffer,&pdu);
for (i=0; i<pdulen;i++)
printf("%02X",pdu[i]);
free(pdu);
printf("\n\r");
see this link about PDU code: http://twit88.com/home/utility/sms-pdu-encode-decode
if some one can help me thanks. |
