PDU encode/decode
filjoa
PDU encode/decode
PostPosted: Wed May 14, 2008 1:34 pm     Reply with quote
Hi
I try encode in PDU mode an string for example "hello word" and I search on this forum but I don't find anything which work..
for example there: http://www.ccsinfo.com/forum/viewtopic.php?t=22619&highlight=pdu
I have this file pduconv.c but it not work with the CCS...
same one know as I change this code for CCS mode?
the result to send "hello word" for my phone in PDU mode with:
service center number: +962100000
mobile phone number: 965542750
is this string:
069169120000F01100099169552457F00000AA0AE8329BFD06DDDF7232
the file which I have is:
#include <string.h>
#include <stdlibm.h>     // Contains malloc() function for CCS
//#include <stdio.h>
#define VERSION 0.1
/* Define Non-Printable Characters as a question mark */
#define NPC7    63
#define NPC8    '?'
// Reduced LU table for save ROM usage
int lookup_ascii8to7[]={
    NPC7,       /*     0      null [NUL]                              */
    NPC7,       /*     1      start of heading [SOH]                  */
    NPC7,       /*     2      start of text [STX]                     */
    NPC7,       /*     3      end of text [ETX]                       */
    NPC7,       /*     4      end of transmission [EOT]               */
    NPC7,       /*     5      enquiry [ENQ]                           */
    NPC7,       /*     6      acknowledge [ACK]                       */
    NPC7,       /*     7      bell [BEL]                              */
    NPC7,       /*     8      backspace [BS]                          */
    NPC7,       /*     9      horizontal tab [HT]                     */
    10,         /*    10      line feed [LF]                          */
    NPC7,       /*    11      vertical tab [VT]                       */
    10+256,     /*    12      form feed [FF]                          */
    13,         /*    13      carriage return [CR]                    */
    NPC7,       /*    14      shift out [SO]                          */
    NPC7,       /*    15      shift in [SI]                           */
    NPC7,       /*    16      data link escape [DLE]                  */
    NPC7,       /*    17      device control 1 [DC1]                  */
    NPC7,       /*    18      device control 2 [DC2]                  */
    NPC7,       /*    19      device control 3 [DC3]                  */
    NPC7,       /*    20      device control 4 [DC4]                  */
    NPC7,       /*    21      negative acknowledge [NAK]              */
    NPC7,       /*    22      synchronous idle [SYN]                  */
    NPC7,       /*    23      end of trans. block [ETB]               */
    NPC7,       /*    24      cancel [CAN]                            */
    NPC7,       /*    25      end of medium [EM]                      */
    NPC7,       /*    26      substitute [SUB]                        */
    NPC7,       /*    27      escape [ESC]                            */
    NPC7,       /*    28      file separator [FS]                     */
    NPC7,       /*    29      group separator [GS]                    */
    NPC7,       /*    30      record separator [RS]                   */
    NPC7,       /*    31      unit separator [US]                     */
    32,         /*    32      space                                   */
    33,         /*    33    ! exclamation mark                        */
    34,         /*    34    " double quotation mark                   */
    35,         /*    35    # number sign                             */
    2,          /*    36    $ dollar sign                             */
    37,         /*    37    % percent sign                            */
    38,         /*    38    & ampersand                               */
    39,         /*    39    ' apostrophe                              */
    40,         /*    40    ( left parenthesis                        */
    41,         /*    41    ) right parenthesis                       */
    42,         /*    42    * asterisk                                */
    43,         /*    43    + plus sign                               */
    44,         /*    44    , comma                                   */
    45,         /*    45    - hyphen                                  */
    46,         /*    46    . period                                  */
    47,         /*    47    / slash,                                  */
    48,         /*    48    0 digit 0                                 */
    49,         /*    49    1 digit 1                                 */
    50,         /*    50    2 digit 2                                 */
    51,         /*    51    3 digit 3                                 */
    52,         /*    52    4 digit 4                                 */
    53,         /*    53    5 digit 5                                 */
    54,         /*    54    6 digit 6                                 */
    55,         /*    55    7 digit 7                                 */
    56,         /*    56    8 digit 8                                 */
    57,         /*    57    9 digit 9                                 */
    58,         /*    58    : colon                                   */
    59,         /*    59    ; semicolon                               */
    60,         /*    60    < less-than sign                          */
    61,         /*    61    = equal sign                              */
    62,         /*    62    > greater-than sign                       */
    63,         /*    63    ? question mark                           */
    0,          /*    64    @ commercial at sign                      */
    65,         /*    65    A uppercase A                             */
    66,         /*    66    B uppercase B                             */
    67,         /*    67    C uppercase C                             */
    68,         /*    68    D uppercase D                             */
    69,         /*    69    E uppercase E                             */
    70,         /*    70    F uppercase F                             */
    71,         /*    71    G uppercase G                             */
    72,         /*    72    H uppercase H                             */
    73,         /*    73    I uppercase I                             */
    74,         /*    74    J uppercase J                             */
    75,         /*    75    K uppercase K                             */
    76,         /*    76    L uppercase L                             */
    77,         /*    77    M uppercase M                             */
    78,         /*    78    N uppercase N                             */
    79,         /*    79    O uppercase O                             */
    80,         /*    80    P uppercase P                             */
    81,         /*    81    Q uppercase Q                             */
    82,         /*    82    R uppercase R                             */
    83,         /*    83    S uppercase S                             */
    84,         /*    84    T uppercase T                             */
    85,         /*    85    U uppercase U                             */
    86,         /*    86    V uppercase V                             */
    87,         /*    87    W uppercase W                             */
    88,         /*    88    X uppercase X                             */
    89,         /*    89    Y uppercase Y                             */
    90,         /*    90    Z uppercase Z                             */
    60+256,     /*    91    [ left square bracket                     */
    47+256,     /*    92    \ backslash                               */
    62+256,     /*    93    ] right square bracket                    */
    20+256,     /*    94    ^ circumflex accent                       */
    17,         /*    95    _ underscore                              */
    -39,        /*    96    ` back apostrophe                         */
    97,         /*    97    a lowercase a                             */
    98,         /*    98    b lowercase b                             */
    99,         /*    99    c lowercase c                             */
    100,        /*   100    d lowercase d                             */
    101,        /*   101    e lowercase e                             */
    102,        /*   102    f lowercase f                             */
    103,        /*   103    g lowercase g                             */
    104,        /*   104    h lowercase h                             */
    105,        /*   105    i lowercase i                             */
    106,        /*   106    j lowercase j                             */
    107,        /*   107    k lowercase k                             */
    108,        /*   108    l lowercase l                             */
    109,        /*   109    m lowercase m                             */
    110,        /*   110    n lowercase n                             */
    111,        /*   111    o lowercase o                             */
    112,        /*   112    p lowercase p                             */
    113,        /*   113    q lowercase q                             */
    114,        /*   114    r lowercase r                             */
    115,        /*   115    s lowercase s                             */
    116,        /*   116    t lowercase t                             */
    117,        /*   117    u lowercase u                             */
    118,        /*   118    v lowercase v                             */
    119,        /*   119    w lowercase w                             */
    120,        /*   120    x lowercase x                             */
    121,        /*   121    y lowercase y                             */
    122,        /*   122    z lowercase z                             */
static int convert_ascii_to_7bit(char *ascii, char *a7bit[]) {
    int r;
    int w;
    r=0;
    w=0;
    /* Allocate sufficient memory for the result string */
    *a7bit=malloc(strlen(ascii)*2+1);
    while (ascii[r]!=0) {
        if ((lookup_ascii8to7[(unsigned char)ascii[r]])<256) {
            *a7bit[w++]=abs(lookup_ascii8to7[(unsigned char)ascii[r++]]);
        } else {
            *a7bit[w++]=27;
            *a7bit[w++]=lookup_ascii8to7[(unsigned char)ascii[r++]]-256;
    /* Realloc the result array to the correct size */
    *a7bit=realloc(*a7bit,w);
    return w;
 *  Convert an ISO-8859-1 ASCII string to an array of PDU-coded bytes
 *  *ascii  The ISO-cleartext to convert
 *  **pdu   Pointer to an array where the pdu-bytes will be stored in, this
 *          function allocates the neccesary memory for the array
 *          Use +pdu[] for CCS
 *  Returns the number of bytes stored in the pdu-array
 *  Note:  Don't forget to free() the pdu-array when you're finished with it.
int ascii_to_pdu(char *ascii, unsigned char *pdu[]) {
    int r;
    int w;
    char *ascii7bit;
    int  len7bit;
    /* Start by converting the ISO-string to a 7bit-string */
    len7bit=convert_ascii_to_7bit(ascii,&ascii7bit);
    *pdu=malloc(len7bit);
    /* Now, we can create a PDU string by packing the 7bit-string */
    r=0;
    w=0;
    while (r<len7bit) {
        *pdu[w]=((ascii7bit[r]>>(w%7))&0x7F) | ((ascii7bit[r+1]<<(7-(w%7)))&0xFF);
        if ((w%7)==6) r++;
        r++;
        w++;
    free(ascii7bit);
    return w;
as I can make an simple program when I have constant string "hello word" and can see them in PDU mode on terminal?
regards
filjoa
PostPosted: Wed May 14, 2008 2:09 pm     Reply with quote
Hi
I make this code but it don't write anything Confused and result correct without number is :
hello word=00110000910000AA0AE8329BFD06DDDF7232
#include <18F452.h>
#device adc=8
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES NOPROTECT                //Code not protected from reading
#FUSES NOOSCSEN                 //Oscillator switching is disabled, main oscillator is source
#FUSES BORV20                   //Brownout reset at 2.0V
#FUSES NOPUT                    //No Power Up Timer
#FUSES NODEBUG                  //No Debug mode for ICD
#FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOWRT                    //Program memory not write protected
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES NOWRTB                   //Boot block not write protected
#FUSES NOWRTC                   //configuration not registers write protected
#FUSES NOCPD                    //No EE protection
#FUSES NOCPB                    //No Boot Block code protection
#FUSES NOEBTR                   //Memory not protected from table reads
#FUSES NOEBTRB                  //Boot block not protected from table reads
#use rs232(baud=115200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
code:
#include "teste_PDU.h"
#include "pduconv.c"
#build(reset=0x200)
#build(interrupt=0x208)
#org 0x0000,0x01ff
void bootloader() {
#asm
  nop
#endasm
} // Reserve space for the bootloader
   int i;
   int pdulen;
   unsigned char *pdu;
   char buffer[];
 printf("string PDU: \n\r");
   buffer="hello word";
   pdulen=ascii_to_pdu(buffer,&pdu);
   for (i=0; i<pdulen;i++)
   printf("%02X",pdu[i]);
   free(pdu);
   printf("\n\r");
see this link about PDU code: http://twit88.com/home/utility/sms-pdu-encode-decode
if some one can help me thanks.
