how can i make the system interrupt for every 60 second? and how can i calculate the cycle if i'm using 4 MHz crystal ? newbie in interrupt, thanks
KU5D
Joined: 10 Feb 2008 Posts: 46 Location: Asheville, North Carolina
Posted: Sun Apr 27, 2008 8:32 am
Can you be a bit more specific? What is it you're trying to do? _________________ Confidence is the feeling you have right before you fully understand the situation...
handsprince
Posted: Sun Apr 27, 2008 7:54 pm
means how can i make the timer to overflow for every 60 seconds
foodwatch
Posted: Sun Apr 27, 2008 8:05 pm
Look in the Code Forum at the real time clock code. You should be able to get fairly decnt timing using tmr overflows...
