interrupt problem
handsprince
interrupt problem
PostPosted: Sun Apr 27, 2008 3:18 am     Reply with quote
how can i make the system interrupt for every 60 second? and how can i calculate the cycle if i'm using 4 MHz crystal ? newbie in interrupt, thanks
KU5D
PostPosted: Sun Apr 27, 2008 8:32 am     Reply with quote
Can you be a bit more specific? What is it you're trying to do?
Confidence is the feeling you have right before you fully understand the situation...
handsprince
PostPosted: Sun Apr 27, 2008 7:54 pm     Reply with quote
means how can i make the timer to overflow for every 60 seconds
foodwatch
PostPosted: Sun Apr 27, 2008 8:05 pm     Reply with quote
Look in the Code Forum at the real time clock code. You should be able to get fairly decnt timing using tmr overflows...
foodwatch
PostPosted: Sun Apr 27, 2008 8:06 pm     Reply with quote
Look at this post in the code section:
Timer based Real Time Clock (RTC)
