assigning bits to arrays
guestplanet
PostPosted: Tue Apr 22, 2008 9:45 pm     Reply with quote
my code
static unsigned int16   reg_event[2];
#bit   bit_event1_1      = reg_event[0].0
#bit   bit_event1_2      = reg_event[0].1
#bit   bit_event1_3      = reg_event[0].2
#bit   bit_event1_4      = reg_event[0].3
#bit   bit_event1_5      = reg_event[0].4
#bit   bit_event1_6      = reg_event[0].5
#bit   bit_event1_7      = reg_event[0].6
#bit   bit_event1_8      = reg_event[0].7
#bit   bit_event1_9      = reg_event[0].8
#bit   bit_event2_1      = reg_event[1].0
#bit   bit_event2_2      = reg_event[1].1
#bit   bit_event2_3      = reg_event[1].2
#bit   bit_event2_4      = reg_event[1].3
#bit   bit_event2_5      = reg_event[1].4
#bit   bit_event2_6      = reg_event[1].5
#bit   bit_event2_7      = reg_event[1].6
#bit   bit_event2_8      = reg_event[1].7
#bit   bit_event2_9      = reg_event[1].8
received error when compiled. please explain what i do wrong?
PostPosted: Tue Apr 22, 2008 10:08 pm     Reply with quote
If you have version 4 of the compiler, then you can do arrays of bits.
See the example program below. It displays this as the output:
10101010
#include <16F877.H>
int1 array_of_bits[20] = {0};
int8 i;
array_of_bits[0] = 1;
array_of_bits[1] = 0;
array_of_bits[2] = 1;
array_of_bits[3] = 0;
array_of_bits[4] = 1;
array_of_bits[5] = 0;
array_of_bits[6] = 1;
array_of_bits[7] = 0;
for(i = 0; i < 8; i++)
    printf("%u", array_of_bits[i]);
guestplanet
PostPosted: Tue Apr 22, 2008 10:38 pm     Reply with quote
found a way to fix this
#bit   bit_event1_1      = reg_event+0.0
#bit   bit_event1_2      = reg_event+0.1
#bit   bit_event1_3      = reg_event+0.2
#bit   bit_event1_4      = reg_event+0.3
#bit   bit_event1_5      = reg_event+0.4
#bit   bit_event1_6      = reg_event+0.5
#bit   bit_event1_7      = reg_event+0.6
#bit   bit_event1_8      = reg_event+0.7
#bit   bit_event1_9      = reg_event+0.8
#bit   bit_event2_1      = reg_event+2.0
#bit   bit_event2_2      = reg_event+2.1
#bit   bit_event2_3      = reg_event+2.2
#bit   bit_event2_4      = reg_event+2.3
#bit   bit_event2_5      = reg_event+2.4
#bit   bit_event2_6      = reg_event+2.5
#bit   bit_event2_7      = reg_event+2.6
#bit   bit_event2_8      = reg_event+2.7
#bit   bit_event2_9      = reg_event+2.8
p.s. wanted to individually assign names to bit variables within a defined array of words
