Posted: Tue Apr 22, 2008 10:08 pm |
If you have version 4 of the compiler, then you can do arrays of bits.
See the example program below. It displays this as the output:
#include <16F877.H>
int1 array_of_bits[20] = {0};
int8 i;
array_of_bits[0] = 1;
array_of_bits[1] = 0;
array_of_bits[2] = 1;
array_of_bits[3] = 0;
array_of_bits[4] = 1;
array_of_bits[5] = 0;
array_of_bits[6] = 1;
array_of_bits[7] = 0;
for(i = 0; i < 8; i++)
printf("%u", array_of_bits[i]);
