Ramey
incorrect code generated for signed ints? |
Posted: Fri Mar 28, 2008 12:49 am |
Below is a small excerpt from a *.lst file generated by my PCH compiler. It looks to me that the code for the x < 0 branch is not being generated. Am I missing something? What should I do about this?
Robert Ramey
CCS PCH C Compiler, Version 4.055, 40531 27-Mar-08 23:35
Filename: LEM.lst
ROM used: 7690 bytes (23%)
Largest free fragment is 25076
RAM used: 1301 (64%) at main() level
1369 (67%) worst case
Stack: 12 worst case (5 in main + 7 for interrupts)
<skipped>...
.................... int8 test(int16 x){
.................... if(x < 0)
.................... return -1;
.................... else
.................... if(x > 0)
1006: MOVLB 1
1008: MOVF x38,F
100A: BNZ 1010
100C: MOVF x39,F
100E: BZ 1018
.................... return 1;
1010: MOVLW 01
1012: MOVWF 01
1014: BRA 101E
1016: BRA 101E
.................... return 0;
1018: MOVLW 00
101A: MOVWF 01
101C: BRA 101E
101E: MOVLB 0
1020: GOTO 12FE (RETURN)
Ramey
Posted: Fri Mar 28, 2008 1:06 am |
OK, I discovered the problem. int16 is by default unsigned. This was certainly a suprise to me - oh well. I wonder why CCS chose to do it differently than every other C compiler in the world - and not emit a warning or compiler error.
Looking at the code
Filename: LEM.lst
<skipped>...
1006: MOVLB 1
1008: MOVF x38,F
100A: BNZ 1010
100C: MOVF x39,F
100E: BZ 1018
1010: MOVLW 01
1012: MOVWF 01
1014: BRA 101E
1016: BRA 101E
1018: MOVLW 00
101A: MOVWF 01
101C: BRA 101E
101E: MOVLB 0
I see two adjacent BRA at 1014 and 1016. Isn't this a waste of memory?
same goes for BRA at 101C. Shouldn't this stuff be filtered out with a peephole optimizer.
Robert Ramey |
Posted: Fri Mar 28, 2008 1:16 am |
If you enable the compiler warning messages, you will see this:
Quote: |
Warning 205 Line 10(1,1): Unsigned variable is never less than zero |
In CCS, all integer data types are unsigned by default. This is in
the manual, in the section on Data Definitions -- Basic and Special Types:
Quote: |
Note: All types, except float, by default are unsigned; however, they
may be preceded by unsigned or signed. |
