incorrect code generated for signed ints?
Ramey
PostPosted: Fri Mar 28, 2008 12:49 am     Reply with quote
Below is a small excerpt from a *.lst file generated by my PCH compiler. It looks to me that the code for the x < 0 branch is not being generated. Am I missing something? What should I do about this?
Robert Ramey
CCS PCH C Compiler, Version 4.055, 40531               27-Mar-08 23:35
               Filename: LEM.lst
               ROM used: 7690 bytes (23%)
                         Largest free fragment is 25076
               RAM used: 1301 (64%) at main() level
                         1369 (67%) worst case
               Stack:    12 worst case (5 in main + 7 for interrupts)
<skipped>...
.................... int8  test(int16 x){
....................     if(x < 0)
....................         return -1;
....................     else
....................     if(x > 0)
1006:  MOVLB  1
1008:  MOVF   x38,F
100A:  BNZ   1010
100C:  MOVF   x39,F
100E:  BZ    1018
....................         return 1;
1010:  MOVLW  01
1012:  MOVWF  01
1014:  BRA    101E
1016:  BRA    101E
....................         return 0;
1018:  MOVLW  00
101A:  MOVWF  01
101C:  BRA    101E
101E:  MOVLB  0
1020:  GOTO   12FE (RETURN)
Ramey
PostPosted: Fri Mar 28, 2008 1:06 am     Reply with quote
OK, I discovered the problem. int16 is by default unsigned. This was certainly a suprise to me - oh well. I wonder why CCS chose to do it differently than every other C compiler in the world - and not emit a warning or compiler error.
Looking at the code
               Filename: LEM.lst
<skipped>...
1006:  MOVLB  1
1008:  MOVF   x38,F
100A:  BNZ   1010
100C:  MOVF   x39,F
100E:  BZ    1018
1010:  MOVLW  01
1012:  MOVWF  01
1014:  BRA    101E
1016:  BRA    101E
1018:  MOVLW  00
101A:  MOVWF  01
101C:  BRA    101E
101E:  MOVLB  0
I see two adjacent BRA at 1014 and 1016. Isn't this a waste of memory?
same goes for BRA at 101C. Shouldn't this stuff be filtered out with a peephole optimizer.
Robert Ramey
PostPosted: Fri Mar 28, 2008 1:16 am     Reply with quote
If you enable the compiler warning messages, you will see this:
Warning 205 Line 10(1,1): Unsigned variable is never less than zero
In CCS, all integer data types are unsigned by default. This is in
the manual, in the section on Data Definitions -- Basic and Special Types:
Note: All types, except float, by default are unsigned; however, they
may be preceded by unsigned or signed.
