sarikayamusa
serial comm with ext interrupt dont work? |
Posted: Fri Mar 28, 2008 1:56 am |
Hi everyone.
I'm working for RF remote dimmer project. But doesnt work true. Problem is: later a few receiving serial data, disabled ext interrupt?
i want to set in ext_int routine with that i received serial time data.
Code is below:
Receiver:
#include <12f675.h>
#FUSES intrc_io,NOMCLR,nowdt
#use rs232(baud=1200,rcv=PIN_A5)
signed int16 gecikme;
#define triac PIN_A4
#define led PIN_A0
#BIT INTF=0x0B.1
#BIT INTEDG=0x81.6
#int_Ext
void isr()
if (gecikme>=0 && gecikme<=10000)
output_low(triac);
delay_us (gecikme);
output_high(triac);
delay_us(300);
output_low(triac);
INTEDG=!INTEDG;
INTF=0;
//clear_interrupt(INT_EXT);
// #byte OSCCAL = 0x90
// #rom 0x3ff = {0x3470}
// if i disable interrupts no problem serial comm.
enable_interrupts(int_ext);
for(;;)
if(kbhit())
disable_interrupts(global); // if any data in, disable interrupt
if(getc()=='A' && getc()=='C') { gecikme=100; enable_interrupts(global); }
if(getc()=='K' && getc()=='P') { gecikme=9900; enable_interrupts(global); }
enable_interrupts(global); // if there isnt serial data, enable interrupt
Transmitter:
#include <12F675.h>
#fuses intrc_IO,NOWDT,nomclr,put //dikkat
#use delay (clock=4000000)
#use rs232(baud=1200,xmit=PIN_A2)
#define BUTON1 PIN_A1
#define BUTON2 PIN_A0
do
if(!input(BUTON2))
{ output_high(pin_a1);
printf("AC");
delay_ms(150);
if(!input(BUTON1))
{ output_low(pin_a1);
printf("KP");
delay_ms(150);
}while(true);
if i disable interrupts, serial comm. working true but if enable, sometimes, ext int disabled. And serial comm doest work true?
Why doesent work my code? Help...
Thanks. |
Matro Guest
Posted: Fri Mar 28, 2008 2:31 am |
These 2 lines
are "dangerous" because once a getc() has been performed, the next one will wait till a new character is received.
So to enable interrupt again there is only a few solutions (x is any character) :
'A', 'C'
x, x, 'K', 'P'
x, x, x, x
ONLY these character series will re-enable the int_ext.
Is that the behavior you want?
Matro. |
