serial comm with ext interrupt dont work?
sarikayamusa
PostPosted: Fri Mar 28, 2008 1:56 am     Reply with quote
Hi everyone.
I'm working for RF remote dimmer project. But doesnt work true. Problem is: later a few receiving serial data, disabled ext interrupt?
i want to set in ext_int routine with that i received serial time data.
Code is below:
Receiver:
#include <12f675.h>
#FUSES intrc_io,NOMCLR,nowdt
#use rs232(baud=1200,rcv=PIN_A5)
signed int16 gecikme;
#define triac   PIN_A4
#define led     PIN_A0
#BIT INTF=0x0B.1
#BIT INTEDG=0x81.6
#int_Ext
void isr()
  if (gecikme>=0 && gecikme<=10000)
   output_low(triac);
   delay_us (gecikme);
   output_high(triac);
   delay_us(300);
   output_low(triac);
  INTEDG=!INTEDG;
  INTF=0;
  //clear_interrupt(INT_EXT);
 //         #byte OSCCAL = 0x90
 //         #rom 0x3ff = {0x3470}
// if i disable interrupts no problem serial comm.
enable_interrupts(int_ext);
   for(;;)
         if(kbhit())
          disable_interrupts(global);    // if any data in, disable interrupt
           if(getc()=='A' && getc()=='C') { gecikme=100;  enable_interrupts(global); }
           if(getc()=='K' && getc()=='P') { gecikme=9900; enable_interrupts(global); }
          enable_interrupts(global);      // if there isnt serial data, enable interrupt
Transmitter:
#include <12F675.h>
#fuses intrc_IO,NOWDT,nomclr,put  //dikkat
#use delay (clock=4000000)
#use rs232(baud=1200,xmit=PIN_A2)
#define BUTON1  PIN_A1
#define BUTON2  PIN_A0
      do
       if(!input(BUTON2))
        {     output_high(pin_a1);
              printf("AC");
               delay_ms(150);
        if(!input(BUTON1))
        {      output_low(pin_a1);
               printf("KP");
               delay_ms(150);
     }while(true);
if i disable interrupts, serial comm. working true but if enable, sometimes, ext int disabled. And serial comm doest work true?
Why doesent work my code? Help...
Thanks.
Matro
PostPosted: Fri Mar 28, 2008 2:31 am     Reply with quote
These 2 lines
are "dangerous" because once a getc() has been performed, the next one will wait till a new character is received.
So to enable interrupt again there is only a few solutions (x is any character) :
'A', 'C'
x, x, 'K', 'P'
x, x, x, x
ONLY these character series will re-enable the int_ext.
Is that the behavior you want?
Matro.
