Posted: Fri Mar 21, 2008 6:31 pm |
Use whatever crystal frequency that you desire. Put the frequency
into the #use delay() statement. Then the compiler will automatically
create the code to make the delay_ms(1000) be for one second.
Example for a 4 MHz crystal:
Code: | #include <16F877.H>
#use delay(clock = 4000000)
output_high(PIN_B0);
output_low(PIN_B0);
