How can reach one second with delay_ms()
USer
PostPosted: Fri Mar 21, 2008 5:43 pm     Reply with quote
Hello there
Could you tell me how can i reach one second by delay_ms(1000)
there should be some extra options like those
//set timing config to 32KHz, restart watchdog timer
//on delay_us() and delay_ms()
#use delay (clock=32000, RESTART_WDT)
What should be the frequency of the pic (i use pic16f877)
Please help
PostPosted: Fri Mar 21, 2008 6:31 pm     Reply with quote
Use whatever crystal frequency that you desire. Put the frequency
into the #use delay() statement. Then the compiler will automatically
create the code to make the delay_ms(1000) be for one second.
Example for a 4 MHz crystal:
#include <16F877.H>
#use delay(clock = 4000000)
   output_high(PIN_B0);
   output_low(PIN_B0);
