Selectable UART stream????
Jason1980
PostPosted: Mon Feb 25, 2008 2:07 pm     Reply with quote
I am using two UARTs in my application. Is there a way to be able to select between two rs232 streams without having to write another fprintf statement that does the same thing?
For example if my variable PORT=1 then I want to send the data out the first UART. If my variable PORT=2 then send data out the second UART
fprintf(PORT,"%d\r",data);
the compiler complains that the stream must be a constant. I'm just wondering if there is a way around this.
thanks
KD5UZZ_
Switch
PostPosted: Tue Feb 26, 2008 3:31 pm     Reply with quote
#use rs232(STREAM=PORT1,xmit=C6,rcv=C7,errors)
#use rs232(STREAM=PORT2,xmit=B2,rcv=B4)
int Port = 1;
switch (Port){
    case 1:
        printf(PORT1,"Blah blah blah");
    case 2:
        printf(PORT2,"Thing to print");
I doubt the #use rs232 lines are valid, but the rest of the code should work.
arunb
RE:
PostPosted: Sat Mar 01, 2008 4:41 am     Reply with quote
The format for selecting from multiple streams is like this
void xmit_port1()
  printf("Blah blah blah");
//For the second stream...
#use rs232(STREAM=PORT2,xmit=C6,rcv=C7,errors)
void xmit_port2()
  printf("Thing to print");
thanks
arunb
