		| Author | Message |
		| Jason1980 Guest
				| Selectable UART stream???? |
				|  Posted: Mon Feb 25, 2008 2:07 pm |   |
				| I am using two UARTs in my application. Is there a way to be able to select between two rs232 streams without having to write another fprintf statement that does the same thing?
 For example if my variable PORT=1 then I want to send the data out the first UART. If my variable PORT=2 then send data out the second UART
 fprintf(PORT,"%d\r",data);
 the compiler complains that the stream must be a constant. I'm just wondering if there is a way around this.
 thanks
		| KD5UZZ_ Guest
				| Switch |
				|  Posted: Tue Feb 26, 2008 3:31 pm |   |
				|  	  | Code: |  	  | #use rs232(STREAM=PORT1,xmit=C6,rcv=C7,errors)
 #use rs232(STREAM=PORT2,xmit=B2,rcv=B4)
 int Port = 1;
 switch (Port){
 case 1:
 printf(PORT1,"Blah blah blah");
 case 2:
 printf(PORT2,"Thing to print");
 I doubt the #use rs232 lines are valid, but the rest of the code should work.
		| arunb
				| RE: |
				|  Posted: Sat Mar 01, 2008 4:41 am |   |
				| Hi,
 The format for selecting from multiple streams is like this
 void xmit_port1()
 printf("Blah blah blah");
 //For the second stream...
 #use rs232(STREAM=PORT2,xmit=C6,rcv=C7,errors)
 void xmit_port2()
 printf("Thing to print");
 thanks
 arunb
 | You cannot post new topics in this forum You cannot reply to topics in this forum
