crukid Guest
Input pins not working properly |
Posted: Sat Feb 23, 2008 2:24 am |
Hello to all!!!
I am having a problem on getting the state of my input pins. below is the code.
#use rs232(baud=2400,xmit=pin_b1,rcv=pin_b2)
#use fast_io(A)
void printID(char *ID);
void alarm();
int rs_state;
int rf_pass;
char rf_id[11];
set_tris_a(0b10);
rf_pass = input(PIN_A1);
if(!rf_pass)
output_low(pin_b5);
output_low(pin_b6);
gets(rf_id);
if(rf_id != "" && rf_id != " ")
printID(rf_id);
int i;
if(ID[1] != 'F' && ID[1] != 'C' && ID != "")
for(i=1;i<150;i++)
if(i < 11)
putc(ID[i]);
OUTPUT_HIGH(PIN_A0);
Delay_us(100);
OUTPUT_LOW(PIN_A0);
Delay_us(100);
output_high(pin_b5);
output_high(pin_b6);
delay_ms( 750 );
void alarm()
int i;
for(i=0; i<150; ++i)
Delay_us(80);
OUTPUT_LOW(PIN_A0);
Delay_us(80);
How this code suppose to work is that when pin A1,assigned to rf_pass, is low the statement inside the IF condtion ,if(!rf_pass),should inside it will execute then will loop after but I am not getting the right response,it seems the pin is not being updated everytime the code loops..hope someone could advice |
stefsun
Posted: Sat Feb 23, 2008 2:46 am |
set_tris_a(0b10); ->set_tris_a(0x02);
int rf_pass; ->int1 rf_pass; |
Posted: Sat Feb 23, 2008 4:07 am |
It is still not effective,could it be a bug in the compiler or limitation? |
