Input pins not working properly
crukid
PostPosted: Sat Feb 23, 2008 2:24 am     Reply with quote
Hello to all!!!
I am having a problem on getting the state of my input pins. below is the code.
#use rs232(baud=2400,xmit=pin_b1,rcv=pin_b2)
#use fast_io(A)
void printID(char *ID);
void alarm();
   int rs_state;
   int rf_pass;
   char rf_id[11];
   set_tris_a(0b10);
   rf_pass = input(PIN_A1);
   if(!rf_pass)
         output_low(pin_b5);
         output_low(pin_b6);
         gets(rf_id);
         if(rf_id != "" && rf_id != " ")
            printID(rf_id);
   int i;
   if(ID[1] != 'F' && ID[1] != 'C' && ID != "")
    for(i=1;i<150;i++)
      if(i < 11)
          putc(ID[i]);
      OUTPUT_HIGH(PIN_A0);
      Delay_us(100);
      OUTPUT_LOW(PIN_A0);
      Delay_us(100);
    output_high(pin_b5);
    output_high(pin_b6);
    delay_ms( 750 );
void alarm()
   int i;
   for(i=0; i<150; ++i)
      Delay_us(80);
      OUTPUT_LOW(PIN_A0);
      Delay_us(80);
How this code suppose to work is that when pin A1,assigned to rf_pass, is low the statement inside the IF condtion ,if(!rf_pass),should inside it will execute then will loop after but I am not getting the right response,it seems the pin is not being updated everytime the code loops..hope someone could advice
stefsun
PostPosted: Sat Feb 23, 2008 2:46 am     Reply with quote
set_tris_a(0b10); ->set_tris_a(0x02);
int rf_pass; ->int1 rf_pass;
PostPosted: Sat Feb 23, 2008 4:07 am     Reply with quote
It is still not effective,could it be a bug in the compiler or limitation?
