Executing: "C:\Program Files\PICC\Ccsc.exe" +FH "sensor_processing.c" +DF +LN +T +A +M +Z +Y=9 +EA
*** Error 164 "C:\Lookup Tables\Sensor_Processing\sensor_processing.h" Line 4(9,17): Selected part does not have ICD debug capability
1 Errors, 0 Warnings.
Skipping link step. Not all sources built successfully.
BUILD FAILED: Sun Feb 17 15:09:25 2008
I am using a PicKit2 which states that ICD IS supported on the 18F4423.
Thanks a bunch!
Posted: Sun Feb 17, 2008 3:25 pm
I took your code fragment and made it into the test program shown
below, and compiled it with PCH vs. 4.068 within MPLAB. It worked OK:
