18F4423 ICD Capability With CCS
stt585
PostPosted: Sun Feb 17, 2008 3:18 pm     Reply with quote
Hi, I need help with this code written for an 18F4423. I have the following in my header file but I keep getting a compiler error.
#include <18F4423.h>
#device adc=16
#device ICD=TRUE
#FUSES HS //High speed Osc (> 4mhz)
And the error I get is:
Executing: "C:\Program Files\PICC\Ccsc.exe" +FH "sensor_processing.c" +DF +LN +T +A +M +Z +Y=9 +EA
*** Error 164 "C:\Lookup Tables\Sensor_Processing\sensor_processing.h" Line 4(9,17): Selected part does not have ICD debug capability
1 Errors, 0 Warnings.
Skipping link step. Not all sources built successfully.
BUILD FAILED: Sun Feb 17 15:09:25 2008
I am using a PicKit2 which states that ICD IS supported on the 18F4423.
Thanks a bunch!
PostPosted: Sun Feb 17, 2008 3:25 pm     Reply with quote
I took your code fragment and made it into the test program shown
below, and compiled it with PCH vs. 4.068 within MPLAB. It worked OK:
BUILD SUCCEEDED: Sun Feb 17 13:19:30 2008
#device adc=16
#device ICD=TRUE
