Using a 18F4685 as a clock?
RageOfFury
PostPosted: Thu Feb 07, 2008 11:45 am     Reply with quote
I have a sensor device that needs a 32.768KHz clock. Can I use one of the timers of the PIC to deliver that clock? If so how?
Oh, the 18F4685 is running off a 20MHz crystal.
Thanx Wink
Neutone
PostPosted: Thu Feb 07, 2008 12:34 pm     Reply with quote
That would mean toggling an output from the PIC every 76.2939453125 instruction cycles.
If you had a crystal of 19922944hz you could toggle it every 76 instruction cycles. This could be done with one of the PWM modules on many PIC's.
