mafia666 Guest
program is not working |
Posted: Thu Feb 07, 2008 3:19 pm |
When this code is running, after few countings program loses time calculation, restarts the calculation from the beginning. Maybe you will see a problem? Do i need to write results to eeprom? Sorry for dumb question - i am really beginner in programing pic uc.
Code: | #include<16f628.h>
#fuses XT,NOWDT,NOPROTECT,NOLVP
#use delay (clock=20000000)
#include"lcd628.c"
//**************** Variables*********************************
int trukme,periodas,sekund,minut,daliklis,a,b,busena,menlaik;
#define voztuvas pin_a2
#define variklis pin_a3
#define tarp pin_a0
#define veikim pin_a1
//**************************Time calculation******************
void laikas()
daliklis=daliklis+1;
if (daliklis==10)
daliklis=0;
sekund=sekund+1;
if (sekund==60)
{sekund=0; minut=minut+1;}
//****************************** Budejimas *************************************
void logo()
lcd_gotoxy(1,1);
printf(lcd_putc," Pramoniniai ");
lcd_gotoxy(1,2);
printf(lcd_putc," Irenginiai ");
//***************************monitoring***********************
void monitoringas()
if (busena==0)
lcd_gotoxy(1,1);
printf(lcd_putc," Iki Atidarymo ");
lcd_gotoxy(1,2);
printf(lcd_putc," Liko - min ");
lcd_gotoxy(7,2);
printf(lcd_putc,"\%02d",a);
if (busena==1)
lcd_gotoxy(1,1);
printf(lcd_putc," Iki Uzdarymo ");
lcd_gotoxy(1,2);
printf(lcd_putc," Liko - sek ");
lcd_gotoxy(7,2);
printf(lcd_putc,"\%02d",b);
//********************* MENIU ***************************
void meniu()
lcd_gotoxy(1,1);
printf(lcd_putc,"Period. - min ");
lcd_gotoxy(1,2);
printf(lcd_putc,"Trukme - sek ");
menlaik=0;
ratukas:
menlaik=menlaik+1;
if(!input(tarp)){menlaik=0; periodas=periodas+1; if(periodas==15){periodas=1;} }
if(!input(veikim)){menlaik=0; trukme=trukme+5; if(trukme==55){trukme=5;}}
lcd_gotoxy(10,1);
printf(lcd_putc,"\%02d",periodas);
lcd_gotoxy(10,2);
printf(lcd_putc,"\%02d",trukme);
delay_ms(200);
if(menlaik<10) goto ratukas;
//************************ process*************************
void vykdymas()
if(!input(variklis))
laikas();
if(periodas==minut) {sekund=0;minut=0;busena=1;output_high(voztuvas);}
if(busena==1 && trukme==sekund){sekund=0;busena=0;output_low(voztuvas);}
a=periodas-minut;b=trukme-sekund;
monitoringas();
logo();
minut=0;sekund=0;
//*********************** main program***********************
output_low(pin_b2);
trukme=25; periodas=5;sekund=0;minut=0;daliklis=0;busena=0;
delay_ms(300);
meni:
if(!input(tarp) || !input(veikim)) meniu();
vykdymas();
goto meni;
ELCouz
Posted: Thu Feb 07, 2008 3:45 pm |
Quote: | #use delay (clock=20000000) |
XT fuses is for slower osc. (<10 mhz) use HS instead!
Code: | meni:
vykdymas();
goto meni; |
uh you mean While ?
Code: | While(1){
vykdymas();
Best Regards,
Laurent |
mafia666 Guest
Posted: Fri Feb 08, 2008 2:20 am |
The thing is, that lcd shows only menu text, it stops to count time, sometimes seems like pic is being restarted. Can it be because of that fuse? Maybe i need to store data in eeprom or etc? |
Posted: Fri Feb 08, 2008 8:40 am |
Quote: | sometimes seems like pic is being restarted. Can it be because of that fuse? | Yes, this is possible. A PIC running at 20MHz needs HS fuse. For 4MHz or slower you use XT. |
