program is not working
mafia666
PostPosted: Thu Feb 07, 2008 3:19 pm     Reply with quote
When this code is running, after few countings program loses time calculation, restarts the calculation from the beginning. Maybe you will see a problem? Do i need to write results to eeprom? Sorry for dumb question - i am really beginner in programing pic uc.
#include<16f628.h>
#fuses XT,NOWDT,NOPROTECT,NOLVP
#use delay (clock=20000000)
#include"lcd628.c"
//**************** Variables*********************************
int trukme,periodas,sekund,minut,daliklis,a,b,busena,menlaik;
#define voztuvas pin_a2
#define variklis pin_a3
#define tarp pin_a0
#define veikim pin_a1
//**************************Time calculation******************
void laikas()
daliklis=daliklis+1;
if (daliklis==10)
  daliklis=0;
  sekund=sekund+1;
  if (sekund==60)
    {sekund=0; minut=minut+1;}
//****************************** Budejimas *************************************
void logo()
  lcd_gotoxy(1,1);
  printf(lcd_putc,"  Pramoniniai  ");
  lcd_gotoxy(1,2);
  printf(lcd_putc,"  Irenginiai    ");
//***************************monitoring***********************
void monitoringas()
if (busena==0)
  lcd_gotoxy(1,1);
  printf(lcd_putc," Iki Atidarymo  ");
  lcd_gotoxy(1,2);
  printf(lcd_putc," Liko    - min  ");
  lcd_gotoxy(7,2);
  printf(lcd_putc,"\%02d",a);
if (busena==1)
lcd_gotoxy(1,1);
  printf(lcd_putc," Iki Uzdarymo  ");
  lcd_gotoxy(1,2);
  printf(lcd_putc," Liko    - sek  ");
  lcd_gotoxy(7,2);
  printf(lcd_putc,"\%02d",b);
//********************* MENIU ***************************
void meniu()
lcd_gotoxy(1,1);
  printf(lcd_putc,"Period. -  min ");
  lcd_gotoxy(1,2);
  printf(lcd_putc,"Trukme  -  sek ");
menlaik=0;
ratukas:
menlaik=menlaik+1;
if(!input(tarp)){menlaik=0; periodas=periodas+1; if(periodas==15){periodas=1;} }
if(!input(veikim)){menlaik=0; trukme=trukme+5; if(trukme==55){trukme=5;}}
  lcd_gotoxy(10,1);
  printf(lcd_putc,"\%02d",periodas);
  lcd_gotoxy(10,2);
  printf(lcd_putc,"\%02d",trukme);
delay_ms(200);
if(menlaik<10) goto ratukas;
//************************ process*************************
void vykdymas()
  if(!input(variklis))
laikas();
if(periodas==minut) {sekund=0;minut=0;busena=1;output_high(voztuvas);}
if(busena==1 && trukme==sekund){sekund=0;busena=0;output_low(voztuvas);}
a=periodas-minut;b=trukme-sekund;
monitoringas();
logo();
minut=0;sekund=0;
//*********************** main program***********************
  output_low(pin_b2);
  trukme=25; periodas=5;sekund=0;minut=0;daliklis=0;busena=0;
  delay_ms(300);
  meni:
    if(!input(tarp) || !input(veikim)) meniu();
    vykdymas();
  goto meni;
ELCouz
PostPosted: Thu Feb 07, 2008 3:45 pm     Reply with quote
XT fuses is for slower osc. (<10 mhz) use HS instead!
  meni:
    vykdymas();
  goto meni;
uh you mean While ?
  While(1){
    vykdymas();
Best Regards,
Laurent
mafia666
PostPosted: Fri Feb 08, 2008 2:20 am     Reply with quote
The thing is, that lcd shows only menu text, it stops to count time, sometimes seems like pic is being restarted. Can it be because of that fuse? Maybe i need to store data in eeprom or etc?
PostPosted: Fri Feb 08, 2008 8:40 am     Reply with quote
Yes, this is possible. A PIC running at 20MHz needs HS fuse. For 4MHz or slower you use XT.
