Exit an interrupt ?
ELCouz
Exit an interrupt ?
PostPosted: Wed Feb 06, 2008 1:04 am     Reply with quote
Dear CCS members,
Take a look at the following code (Full code here):
#INT_TIMER1
void timer_irq()
    set_timer1(preload);
   if (Intcount < 255)
      if (Intcount == red_duty)
         output_low(red);
      if (Intcount == green_duty)
         output_low(green);
      if (Intcount == blue_duty)
         output_low(blue);
   else if(Intcount == 255)
      Intcount = 0;
      output_high(red);
      output_high(green);
      output_high(blue);
    Intcount++;
Is there a way to skip the remaining Intcount++; code when i reset it to 0 better (more efficient way) than doing :
      restart_pwm = 1;
      output_high(pin_a0);
      output_high(pin_a1);
      output_high(pin_a2);
    Intcount++;
    if(restart_pwm==1){
    Intcount=0;
    restart_pwm = 0;
... Like exiting the current interrupt so it would not run the rest of the interrupt code for this time only thus having a real 0 value for Intcount instead of resetting it to 0 then increasing to 1 after.
Just curious!
Best Regards,
Laurent
Foppie
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Wed Feb 06, 2008 1:24 am     Reply with quote
Why not just delete the line Intcount = 0; ?
This way the Intcount will overflow to 0. (as long as it is an int)
It is not the most dynamic approach, but it works in this case.
ELCouz
PostPosted: Wed Feb 06, 2008 1:32 am     Reply with quote
Thanks !
I never thought of that.
Laurent
D-Kens
PostPosted: Wed Feb 06, 2008 2:13 am     Reply with quote
Guess you could also have included your "Intcount++" into the 'if(Intcount<255)', thus increasing only as long as your below 255...
Wink
