ELCouz
Exit an interrupt ? |
Posted: Wed Feb 06, 2008 1:04 am |
Dear CCS members,
Take a look at the following code (Full code here):
#INT_TIMER1
void timer_irq()
set_timer1(preload);
if (Intcount < 255)
if (Intcount == red_duty)
output_low(red);
if (Intcount == green_duty)
output_low(green);
if (Intcount == blue_duty)
output_low(blue);
else if(Intcount == 255)
Intcount = 0;
output_high(red);
output_high(green);
output_high(blue);
Intcount++;
Is there a way to skip the remaining Intcount++; code when i reset it to 0 better (more efficient way) than doing :
restart_pwm = 1;
output_high(pin_a0);
output_high(pin_a1);
output_high(pin_a2);
Intcount++;
if(restart_pwm==1){
Intcount=0;
restart_pwm = 0;
... Like exiting the current interrupt so it would not run the rest of the interrupt code for this time only thus having a real 0 value for Intcount instead of resetting it to 0 then increasing to 1 after.
Just curious!
Best Regards,
Laurent |
Foppie
Joined: 16 Sep 2005 Posts: 138 Location: The Netherlands
Posted: Wed Feb 06, 2008 1:24 am |
Why not just delete the line Intcount = 0; ?
This way the Intcount will overflow to 0. (as long as it is an int)
It is not the most dynamic approach, but it works in this case. |
ELCouz
Posted: Wed Feb 06, 2008 1:32 am |
Thanks !
I never thought of that.
Laurent |
D-Kens
Joined: 09 May 2005 Posts: 35 Location: Toulouse (France)
Posted: Wed Feb 06, 2008 2:13 am |
Guess you could also have included your "Intcount++" into the 'if(Intcount<255)', thus increasing only as long as your below 255...
![Wink](images/smiles/icon_wink.gif) |
