		| Author | Message |
		| smiles
				| atoi function |
				|  Posted: Fri Feb 22, 2008 9:00 am |   |
				| My task is press button to select time for relay on and off, but it doesn't work now, here is my code, hope you show me where I am wrong (my LCD works well as I expect, I think the problem lie in my C coding)
  	  | Code: |  	  | int array[16]={'1','4','7','<','2','5','8','0','3','6','9','>','C','&','E','M'};
 int keyPressed;
 int16 timeResult;
 // declare functions ...
 // TODO: USER CODE!!
 InitPic();
 InitLcd();
 timeResult=Keypad();
 do
 output_high(PIN_C0);
 delay_ms(timeResult);
 output_low(PIN_C0);
 int OnRelease()
 int i,j,k;
 int value[4]={0x07,0x0B,0x0D,0x0E};
 set_tris_a(0x0f);
 k=0;
 for(i=0;i<4;i++)
 output_d(value[i]);
 delay_us(100);
 for(j=0;j<4;j++)
 if(!input(40+j))
 do
 delay_ms(50);
 while(!input(40+j));
 return k;
 k++;
 return -1;
 int16 Keypad()
 char number[];
 int iNum;
 int16 numResult;
 timeResult=0;
 do
 keyPressed=OnRelease();
 if ((array[keyPressed] > 0x2F) && (array[keyPressed] < 0x3A))   // for numbers 0-9 only
 WrDat2Lcd(array[keyPressed]);
 number[iNum]=array[keyPressed];
 iNum++;
 if (array[keyPressed] == 'E')   // press Enter key to exit function
 number[iNum]='\0';
 numResult=atoi(number);
 return numResult;
 Thanks !!!
		| SET
				|  Posted: Fri Feb 22, 2008 1:57 pm |   |
				|  	  | Quote: |  	  |  	  | Code: |  	  | int OnRelease() {
 int i,j,k;
 set_tris_a(0x0f);
 k=0;
 for(i=0;i<4;i++)
 output_d(value[i]);
 delay_us(100);
 for(j=0;j<4;j++)
 if(!input(40+j))
 do
 delay_ms(50);
 return k;
 k++;
 return -1;         // << signed return value!
 Remember ints are unsigned in CCS so this function may not work as you expect it to..
 Also..
  	  | Quote: |  	  |  	  | Code: |  	  | int16 Keypad() {
 char number[];
 You need to set a size for 'number'
 And Ive just noticed that you dont initialise inum
 | You cannot post new topics in this forum You cannot reply to topics in this forum
