atoi function
smiles
atoi function
PostPosted: Fri Feb 22, 2008 9:00 am     Reply with quote
My task is press button to select time for relay on and off, but it doesn't work now, here is my code, hope you show me where I am wrong (my LCD works well as I expect, I think the problem lie in my C coding)
   int array[16]={'1','4','7','<','2','5','8','0','3','6','9','>','C','&','E','M'};
   int keyPressed;
   int16 timeResult;
// declare functions ...
   // TODO: USER CODE!!
   InitPic();
   InitLcd();
   timeResult=Keypad();
   do
   output_high(PIN_C0);
   delay_ms(timeResult);
   output_low(PIN_C0);
int OnRelease()
   int i,j,k;
   int value[4]={0x07,0x0B,0x0D,0x0E};
   set_tris_a(0x0f);
   k=0;
   for(i=0;i<4;i++)
      output_d(value[i]);
      delay_us(100);
      for(j=0;j<4;j++)
         if(!input(40+j))
            do
               delay_ms(50);
            while(!input(40+j));
            return k;
            k++;
   return -1;
int16 Keypad()
   char number[];
   int iNum;
   int16 numResult;
   timeResult=0;
   do
   keyPressed=OnRelease();
   if ((array[keyPressed] > 0x2F) && (array[keyPressed] < 0x3A))   // for numbers 0-9 only
      WrDat2Lcd(array[keyPressed]);
      number[iNum]=array[keyPressed];
      iNum++;
   if (array[keyPressed] == 'E')   // press Enter key to exit function
      number[iNum]='\0';
      numResult=atoi(number);
      return numResult;
Thanks !!!
SET
PostPosted: Fri Feb 22, 2008 1:57 pm     Reply with quote
int OnRelease()
   int i,j,k;
   set_tris_a(0x0f);
   k=0;
   for(i=0;i<4;i++)
      output_d(value[i]);
      delay_us(100);
      for(j=0;j<4;j++)
         if(!input(40+j))
            do
               delay_ms(50);
            return k;
            k++;
   return -1;         // << signed return value!
Remember ints are unsigned in CCS so this function may not work as you expect it to..
Also..
int16 Keypad()
   char number[];
You need to set a size for 'number'
And Ive just noticed that you dont initialise inum
