Ossyle
RS232 communication problem |
Posted: Mon Dec 03, 2007 7:01 am |
Hi.
I am trying to RS232 communication with 16F628-04/P UART but I didn't success. I did simple practice. For example I receive RS232 data with getch() function and write porta by leds. I simulate circuit with Proteus, its work. But I didn't work on breadbord. Please help for this.
Sorry about bad english.
Circuit
Program.c
Code: | #include "C:\Program Files\PICC\Projects\628yeni.h"
int deg;
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
output_a(0);
deg=getc();
if(deg!="")
output_a(deg);
Program.h
Code: | #include <16F628.h>
#FUSES PROTECT //Code protected from reads
#use rs232(baud=9600,parity=N,xmit=PIN_B2,rcv=PIN_B1,bits=8) |
Thanks for help. |
SherpaDoug
Posted: Mon Dec 03, 2007 11:00 am |
You should NOT connect an RS232 signal directly to a PIC pin. The RS232 signal voltage can swing as much as +15V to -15V which can seriously damage a PIC.
The best way is to use an RS232 driver chip like the MAX232. You can learn a lot by reading the MAX232 datasheet even if you don't use that chip.
For receiving only you can probably get away with a simple 10k resistor between the RS232 connector and the PIC, especially at moderate baud rates like 9600 baud. _________________ The search for better is endless. Instead simply find very good and get the job done. |
Posted: Mon Dec 03, 2007 11:11 am |
Also, remember that unless an inverter is present, the 'invert' option is needed in the RS232 setup.
