RS232 communication problem
Ossyle
PostPosted: Mon Dec 03, 2007 7:01 am     Reply with quote
Hi.
I am trying to RS232 communication with 16F628-04/P UART but I didn't success. I did simple practice. For example I receive RS232 data with getch() function and write porta by leds. I simulate circuit with Proteus, its work. But I didn't work on breadbord. Please help for this.
Sorry about bad english.
Circuit
Program.c
#include "C:\Program Files\PICC\Projects\628yeni.h"
int deg;
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
output_a(0);
deg=getc();
if(deg!="")
output_a(deg);
Program.h
#include <16F628.h>
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES NOPUT                    //No Power Up Timer
#FUSES PROTECT                  //Code protected from reads
#FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOCPD                    //No EE protection
#use rs232(baud=9600,parity=N,xmit=PIN_B2,rcv=PIN_B1,bits=8)
Thanks for help.
SherpaDoug
PostPosted: Mon Dec 03, 2007 11:00 am     Reply with quote
You should NOT connect an RS232 signal directly to a PIC pin. The RS232 signal voltage can swing as much as +15V to -15V which can seriously damage a PIC.
The best way is to use an RS232 driver chip like the MAX232. You can learn a lot by reading the MAX232 datasheet even if you don't use that chip.
For receiving only you can probably get away with a simple 10k resistor between the RS232 connector and the PIC, especially at moderate baud rates like 9600 baud.
PostPosted: Mon Dec 03, 2007 11:11 am     Reply with quote
Also, remember that unless an inverter is present, the 'invert' option is needed in the RS232 setup.
