Hello. I want to use a PIC12F510 to produce a rough 4KHz signal using timer 0 but can't seem to get it to work as the compiler keeps saying 'Invalid Pre-Processor Directive' to the line '#INT_RTCC'.
Am I doing something wrong or am I going to need a different PIC?
I'm using the internal 8MHz oscillator.
My compiler version is 3.245.
#FUSES IOSC8 //Internal 8 MHz oscillator.
//#FUSES RB4 //B4 is an I/O pin not CLKOUT
#use delay(clock=8000000)
Posted: Fri Nov 30, 2007 12:21 pm
I don't think this PIC has any interrupts. There's no mention of it
in the data sheet.
rnielsen
Posted: Fri Nov 30, 2007 2:59 pm
Yup. This device has a timer/counter but the data sheet shows no interrupt flag going anywhere. Just the ability to ready the timer register. I even tried to use the wizard and it shows no interrupts to be set up.
If you need an interrupt you'll need to select a different part. It stinks but it's called a learning curve.
Ronald
monkeytennis
Posted: Mon Dec 03, 2007 4:29 am
So I see.
I'm not used to these PICs, I mostly use the 18FXXX series. I must have completely overlooked the lack of interrupts!
