Using TIMER0 with a PIC12F510
monkeytennis
PostPosted: Fri Nov 30, 2007 9:55 am     Reply with quote
Hello. I want to use a PIC12F510 to produce a rough 4KHz signal using timer 0 but can't seem to get it to work as the compiler keeps saying 'Invalid Pre-Processor Directive' to the line '#INT_RTCC'.
Am I doing something wrong or am I going to need a different PIC?
I'm using the internal 8MHz oscillator.
My compiler version is 3.245.
Thanks, Simon.
main.c
#include "blah blah blah\main.h"
int8 level4k = 0;
int8 level80 = 0;
#INT_RTCC
void clock_isr()
   set_timer0(6);
   if (level4k)
      level4k = 0;
      level4k = 1;
   output_b(level4k);
   setup_adc_ports(AN0_AN1_AN2);
   setup_comparator(NC_NC);
main.h
#include <12F510.h>
//#device adc=8
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES IOSC8                  //Internal 8 MHz oscillator.
#FUSES NOPROTECT                //Code not protected from reading
#FUSES MCLR                     //Master Clear pin enabled
//#FUSES RB4                      //B4 is an I/O pin not CLKOUT
#use delay(clock=8000000)
PostPosted: Fri Nov 30, 2007 12:21 pm     Reply with quote
I don't think this PIC has any interrupts. There's no mention of it
in the data sheet.
rnielsen
PostPosted: Fri Nov 30, 2007 2:59 pm     Reply with quote
Yup. This device has a timer/counter but the data sheet shows no interrupt flag going anywhere. Just the ability to ready the timer register. I even tried to use the wizard and it shows no interrupts to be set up.
If you need an interrupt you'll need to select a different part. It stinks but it's called a learning curve.
Ronald
monkeytennis
PostPosted: Mon Dec 03, 2007 4:29 am     Reply with quote
So I see. Embarassed
I'm not used to these PICs, I mostly use the 18FXXX series. I must have completely overlooked the lack of interrupts!
Thanks very much for your help. Smile
