I'm really just looking for someone to help me out with this code, I know there has to be any easier way to configure all the registers in the AD7147 that I'm using, but I just don't know how to code it, here is what I have so far:
All I have to do is go through a list of registers and assign them values, I just don't know how to do it an easier way. Could someone please show me how to do this easier?
SherpaDoug
Posted: Thu Nov 29, 2007 10:13 am
Some of the i2c devices I have worked with autoincrement the address between bytes. This allows you to write to consecutive bytes by just addressing the first byte and then writing multiple bytes. _________________ The search for better is endless. Instead simply find very good and get the job done.
achotto
Posted: Thu Nov 29, 2007 11:52 am
"The AD7147-1 address pointer register automatically increments after each write. This allows the master to sequentially write to all registers on the AD7147-1 in the same write transaction"
This is a quote from the data sheet of the AD7147. So can you give me an example of how I would write to a set of sequential registers? would I just do a lot of i2c_write() commands in a row?
