Simple i2c programming issue
achotto
PostPosted: Thu Nov 29, 2007 9:59 am     Reply with quote
I'm really just looking for someone to help me out with this code, I know there has to be any easier way to configure all the registers in the AD7147 that I'm using, but I just don't know how to code it, here is what I have so far:
[/code]
#include <18F4520.h>
#include <AD7147RegMap.h>
#use i2c(Master, sda=PIN_C4, scl=PIN_C3)
i2c_start();
i2c_write(STAGE0_CONNECTION);
i2c_write(0xFFFE);
i2c_stop();
i2c_start();
i2c_write(STAGE0_CONNECTION+1);
i2c_write(0x1FFF);
i2c_stop();
i2c_start();
i2c_write(STAGE0_CONNECTION+2);
i2c_write(0x0000);
i2c_stop();
All I have to do is go through a list of registers and assign them values, I just don't know how to do it an easier way. Could someone please show me how to do this easier?
SherpaDoug
PostPosted: Thu Nov 29, 2007 10:13 am     Reply with quote
Some of the i2c devices I have worked with autoincrement the address between bytes. This allows you to write to consecutive bytes by just addressing the first byte and then writing multiple bytes.
achotto
PostPosted: Thu Nov 29, 2007 11:52 am     Reply with quote
"The AD7147-1 address pointer register automatically increments after each write. This allows the master to sequentially write to all registers on the AD7147-1 in the same write transaction"
This is a quote from the data sheet of the AD7147. So can you give me an example of how I would write to a set of sequential registers? would I just do a lot of i2c_write() commands in a row?
