Ken Johnson
Joined: 23 Mar 2006 Posts: 197 Location: Lewisburg, WV
| addressmod, #type |
Posted: Wed Nov 07, 2007 2:16 pm |
Can someone spot the error of my ways here:
#define CRYSTAL 40000000
#include "18F8722.h"
#device ANSI
#device ICD=TRUE
#pragma device CCSICD=TRUE
#fuses DEBUG,NOWDT
#fuses H4
#use delay(clock=CRYSTAL,RESTART_WDT)
#use RS232 (DEBUGGER,DISABLE_INTS)
addressmod(FASTRAM,0x0100,0x015F);
#type default=FASTRAM // This line gives "Error: Unknown Type"
int8 pa = 0;
#type default=
void main (void)
for ( ;; ) {
if ( pa == 0 )
pa = 0x20;
else pa >>= 1;
I've read the help file, searched the forum. Must have overlooked something really simple. The compiler (PCH V4.060) gives "Error: Unknown type" on the #type line following addressmod(). What am I missing?
Thanks all,
Ken |
Posted: Wed Nov 07, 2007 3:02 pm |
CCS's own example from the #type section in their manual doesn't work.
It gives the same error messsage.
I suggest you email CCS support and ask them about it.
| Code: | #include <18F452.h>
#fuses XT,NOWDT,BROWNOUT,PUT,NOLVP
//#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
#TYPE default=area
addressmod (user_ram_block, 0x100, 0x1FF);
#type default=user_ram_block
#type default=
Ken Johnson
Posted: Wed Nov 07, 2007 3:16 pm |
Thanks PCM - I have done that, and will post their response.
Ken |
Ken Johnson
Posted: Wed Nov 07, 2007 3:36 pm |
Wow, these guys are quick !
From CCS:
For RAM use you need two blank arguments as follows:
addressmod(FASTRAM,,,0x050,0x05F);
It verifying this here I did find two compiler issues however. We did not allow
the = to initialize when it should be OK for RAM and the identifiers did not show
in the .SYM file. Both issues are fixed in the 4.061 release coming out today.
So, watching for 4.061
Ken |
