addressmod, #type
Ken Johnson
addressmod, #type
PostPosted: Wed Nov 07, 2007 2:16 pm     Reply with quote
Can someone spot the error of my ways here:
#define CRYSTAL     40000000
#include "18F8722.h"
#device ANSI
#device ICD=TRUE
#pragma device CCSICD=TRUE
#fuses  DEBUG,NOWDT
#fuses  H4
#use delay(clock=CRYSTAL,RESTART_WDT)
#use RS232 (DEBUGGER,DISABLE_INTS)
addressmod(FASTRAM,0x0100,0x015F);
#type   default=FASTRAM         //  This line gives "Error: Unknown Type"
int8    pa = 0;
#type   default=
void    main (void)
    for ( ;; ) {
        if ( pa  == 0 )
            pa = 0x20;
        else pa >>= 1;
I've read the help file, searched the forum. Must have overlooked something really simple. The compiler (PCH V4.060) gives "Error: Unknown type" on the #type line following addressmod(). What am I missing?
Thanks all,
Ken
PostPosted: Wed Nov 07, 2007 3:02 pm     Reply with quote
CCS's own example from the #type section in their manual doesn't work.
It gives the same error messsage.
I suggest you email CCS support and ask them about it.
#include <18F452.h>
#fuses XT,NOWDT,BROWNOUT,PUT,NOLVP
//#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
#TYPE default=area
addressmod (user_ram_block, 0x100, 0x1FF);
#type default=user_ram_block
#type default=
Ken Johnson
PostPosted: Wed Nov 07, 2007 3:16 pm     Reply with quote
Thanks PCM - I have done that, and will post their response.
Ken
Ken Johnson
PostPosted: Wed Nov 07, 2007 3:36 pm     Reply with quote
Wow, these guys are quick !
From CCS:
For RAM use you need two blank arguments as follows:
addressmod(FASTRAM,,,0x050,0x05F);
It verifying this here I did find two compiler issues however. We did not allow
the = to initialize when it should be OK for RAM and the identifiers did not show
in the .SYM file. Both issues are fixed in the 4.061 release coming out today.
So, watching for 4.061 Smile
Ken
