The Puma
Joined: 23 Apr 2004 Posts: 227 Location: The Netherlands
Timer0 questions |
Posted: Tue Oct 02, 2007 9:50 am |
i have this little programs thats blinks two leds.
How can i calculate om which freq the leds blinks?
Code: | #include <18F4620.h>
#fuses HS,NOWDT,NOBROWNOUT,NOPUT,NOLVP,DEBUG,NOSTVREN,NOPROTECT
int8 GL1_counter,GL2_counter;
#define Green_Led_1 PIN_C1
#define Green_Led_2 PIN_C2
// LEDs blinking-time constants
#define Green_Led_1_blink 4
#define Green_Led_2_blink 8
#int_RTCC
void RTCC_isr() {
GL1_counter--;
if(!GL1_counter) {
GL1_counter=Green_Led_1_blink;
output_toggle(Green_Led_1);
GL2_counter--;
if(!GL2_counter) {
GL2_counter=Green_Led_2_blink;
output_toggle(Green_Led_2);
enable_interrupts(INT_RTCC);
while(TRUE) {
// Your can do anything here while
// your Leds are blinking in background
Neutone
Re: Timer0 questions |
Posted: Tue Oct 02, 2007 11:09 am |
The [spam] wrote: | i have this little programs thats blinks two leds.
#int_RTCC
void RTCC_isr() {
GL1_counter--;
if(!GL1_counter) {
GL2_counter--;
if(!GL2_counter) {
while(TRUE) {
f=fosc*(1/4)*(1/(2^16))*(1/2)*(1/Green_Led_1_blink)=9.53 HZ
fosc = 20MHZ
1 instruction cycle per oscilator cycle = 1/4
time0 increments (2^16) times per interupt
Output is both on and off =2 |
The Puma
Posted: Tue Oct 02, 2007 11:36 am |
@Neutone,
Ok, but how can i calculate if i want a 5 hz freq
Which value must Green_Led_1_blink have? |
The Puma
Posted: Tue Oct 02, 2007 3:48 pm |
Strange result for this example
This give a freq of 19.5Khz (scope)
but this should be 39Khz
Do i something wrong???
// The cycle time will be (1/clock)*4*t2div*(period+1)
// In this program clock=20000000 and period=127
// (1/20000000)*4*1*128=25.6us or 39.0khz
#int_TIMER2
void TIMER2_isr() {
output_toggle(PIN_C1);
setup_timer_2(T2_DIV_BY_1,127,1);
while(TRUE) {
// your Led are blinking in background
