Timer0 questions
The Puma
Timer0 questions
PostPosted: Tue Oct 02, 2007 9:50 am     Reply with quote
i have this little programs thats blinks two leds.
How can i calculate om which freq the leds blinks?
#include <18F4620.h>
#fuses HS,NOWDT,NOBROWNOUT,NOPUT,NOLVP,DEBUG,NOSTVREN,NOPROTECT
int8 GL1_counter,GL2_counter;
#define Green_Led_1      PIN_C1
#define Green_Led_2      PIN_C2
// LEDs blinking-time constants
#define Green_Led_1_blink  4
#define Green_Led_2_blink  8
#int_RTCC
void RTCC_isr() {
   GL1_counter--;
   if(!GL1_counter) {
      GL1_counter=Green_Led_1_blink;
      output_toggle(Green_Led_1);
   GL2_counter--;
   if(!GL2_counter) {
      GL2_counter=Green_Led_2_blink;
      output_toggle(Green_Led_2);
   enable_interrupts(INT_RTCC);
   while(TRUE) {
      // Your can do anything here while
      // your Leds are blinking in background
Neutone
Re: Timer0 questions
PostPosted: Tue Oct 02, 2007 11:09 am     Reply with quote
#int_RTCC
void RTCC_isr() {
   GL1_counter--;
   if(!GL1_counter) {
   GL2_counter--;
   if(!GL2_counter) {
   while(TRUE) {
f=fosc*(1/4)*(1/(2^16))*(1/2)*(1/Green_Led_1_blink)=9.53 HZ
fosc = 20MHZ
1 instruction cycle per oscilator cycle = 1/4
time0 increments (2^16) times per interupt
Output is both on and off =2
The Puma
PostPosted: Tue Oct 02, 2007 11:36 am     Reply with quote
@Neutone,
Ok, but how can i calculate if i want a 5 hz freq
Which value must Green_Led_1_blink have?
The Puma
PostPosted: Tue Oct 02, 2007 3:48 pm     Reply with quote
Strange result for this example
This give a freq of 19.5Khz (scope)
but this should be 39Khz
Do i something wrong???
//   The cycle time will be (1/clock)*4*t2div*(period+1)
//   In this program clock=20000000 and period=127
//   (1/20000000)*4*1*128=25.6us or 39.0khz
#int_TIMER2
void TIMER2_isr() {
   output_toggle(PIN_C1);
   setup_timer_2(T2_DIV_BY_1,127,1);
   while(TRUE) {
      // your Led are blinking in background
