hey im new to pics, have been using amtel, and ccs and have downloaded mplab which i think had the ccs driver but whenever i try complie it says
Executing: "C:\Program Files\Microchip\Third Party\PICC\CCSC.EXE" +FM "adcrs232.c" +DF +LN +T +A +M +Z +Y=9 +EA
Error: The selected compiler: "PCM" is not installed on this PC
Halting build on first failure as requested.
BUILD FAILED: Tue Aug 28 11:35:58 2007
why is this happening?
thanks
Posted: Mon Aug 27, 2007 6:24 pm
I think you only get the PCB compiler with MPLAB. It doesn't support
common PICs such as the 16F877. That requires the PCM compiler.
Here's a list of the supported PICs. Every one that has a "B" next to
it is supported by the PCB compiler:
http://www.ccsinfo.com/devices.php?page=devices
