-> operator
gordon111
-> operator
PostPosted: Wed Aug 22, 2007 3:05 pm     Reply with quote
Can anyone please give me a hint as what this operator (->) does...for example.
   if(cb->buf[0] == readDips())         // Valid Address
         switch(cb->buf[1])               // Function
            case 0x01:   // Read Coil Status
               readCoils();                        // Read status of Coils
PostPosted: Wed Aug 22, 2007 3:53 pm     Reply with quote
http://www.amazon.com/C-Programming-Language-2nd/dp/0131103628
The arrow notation is used when dereferencing a pointer to a structure. On function calling it is often more efficient to pass a pointer to a structure than passing (a copy of) the structure.
To dereference the structure you could write code like
(*cb).buf[1]
Note, the parentheses are necessary here because the . operator has higher precedence than the indirection operator, *. We must first dereference the pointer, and then select its appropriate member.
Since dereferencing structures like this is a common task they have defined a special pointer operator, called arrow, and the above code becomes:
cb->buf[1]
