The arrow notation is used when dereferencing a pointer to a structure. On function calling it is often more efficient to pass a pointer to a structure than passing (a copy of) the structure.
To dereference the structure you could write code like
(*cb).buf[1]
Note, the parentheses are necessary here because the . operator has higher precedence than the indirection operator, *. We must first dereference the pointer, and then select its appropriate member.
Since dereferencing structures like this is a common task they have defined a special pointer operator, called arrow, and the above code becomes:
