The Puma
Joined: 23 Apr 2004 Posts: 227 Location: The Netherlands
Lowest freq. with timer2 |
Posted: Mon Aug 20, 2007 12:12 pm |
Give this code the lowest freq for times 2?
#include <18F4620.h>
#fuses HS,NOWDT,NOBROWNOUT,NOPUT,NOLVP,DEBUG,NOSTVREN,NOPROTECT
#int_TIMER2
void TIMER2_isr() {
output_toggle(PIN_C1);
setup_timer_2(T2_DIV_BY_16,249,16);
while(TRUE);
Humberto
Posted: Mon Aug 20, 2007 1:03 pm |
setup_timer_2(T2_DIV_BY_16,255,16);
Should give an interrupt every 13.1ms (@20Mhz xtal clock)
Humberto |
