Lowest freq. with timer2
The Puma
PostPosted: Mon Aug 20, 2007 12:12 pm     Reply with quote
Give this code the lowest freq for times 2?
#include <18F4620.h>
#fuses HS,NOWDT,NOBROWNOUT,NOPUT,NOLVP,DEBUG,NOSTVREN,NOPROTECT
#int_TIMER2
void TIMER2_isr() {
   output_toggle(PIN_C1);
void main() {
   setup_timer_2(T2_DIV_BY_16,249,16);
   while(TRUE);
Humberto
PostPosted: Mon Aug 20, 2007 1:03 pm     Reply with quote
setup_timer_2(T2_DIV_BY_16,255,16);
Should give an interrupt every 13.1ms (@20Mhz xtal clock)
Humberto
