I have a string of variable length that is received from another device via serial port in the following format (without quotes)
"data7E3B99D7"
After the word data, I need to extract each 2 characters into an int8 array as follows:
mydata[0] = 0x7E
mydata[1] = 0x3B
mydata[2] = 0x99
mydata[3] = 0xD7
Can someone give me a piece of code that can convert the string data into hex numbers and put them in this array?
