String to Hex number
Freddie
PostPosted: Wed Jun 20, 2007 10:37 am     Reply with quote
Using Compiler PCM 3.242, PIC 16F877.
I have a string of variable length that is received from another device via serial port in the following format (without quotes)
"data7E3B99D7"
After the word data, I need to extract each 2 characters into an int8 array as follows:
mydata[0] = 0x7E
mydata[1] = 0x3B
mydata[2] = 0x99
mydata[3] = 0xD7
Can someone give me a piece of code that can convert the string data into hex numbers and put them in this array?
Thanks.
PostPosted: Wed Jun 20, 2007 2:30 pm     Reply with quote
To extract 2-byte strings, you could use the the method shown
in this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=27121
To convert the 2-byte strings to integer values:
http://www.ccsinfo.com/forum/viewtopic.php?p=70543
PostPosted: Thu Jun 21, 2007 5:59 am     Reply with quote
These look like exactly what I need. I'll try them today. Thanks PCM Programmer!!
Freddie
PostPosted: Thu Jun 21, 2007 5:19 pm     Reply with quote
Works perfect. Thanks PCM programmer.
