Very quick 16F677 I2C question: Can it support FAST mode?
Posted: Thu Jun 07, 2007 5:29 pm
Can the 16F677 support "FAST" I2C mode? I didn't see it in the instruction manual.
I'm using the 16F677 as an I2C slave to another PIC micro which acts as the I2C master.
Thanks!
Posted: Fri Jun 08, 2007 2:55 am
Yes, FAST mode is supported.
Please note the minimum clock speeds required in order to comply with the I2C specifications. From the PIC16F690 datasheet table 17-14:
- 100kHz mode requires a clock speed minimum of 1.5MHz.
- 400kHz mode requires a clock speed minimum of 10MHz.
