internal interrupt and back key
ahmad-al3omar
PostPosted: Fri Jun 08, 2007 1:35 am     Reply with quote
hello
how can i write an internal interrupt code which do subrotine when the key of the key pad is pressed , like reset key ;
and how can i make a back key in the keypad ,
thank you
A.T.N
PostPosted: Fri Jun 08, 2007 12:33 pm     Reply with quote
How can I write an internal interrupt code which do subroutine
when the key of the key pad is pressed ?
You can use the #INT_RB interrupts, on pins B4 to B7. Here's one
example:
http://www.ccsinfo.com/forum/viewtopic.php?t=19726
Hw can Imake a back key in the keypad
You can use the '*' key as the backspace key. When that key is
pressed, send a backspace command to your display routine.
